Whadya all think?
PostPosted: Sat May 14, 2011 7:13 pm    Post subject: Whadya all think? Reply with quote
"Light Machine Grey." I figure it's a Chevy, and this way I can see everything that inevitably leaks out of it. Very Happy
Either way it's an improvement from before...
PostPosted: Sat May 14, 2011 7:21 pm    Post subject: Reply with quote
Looks clean.
PostPosted: Sat May 14, 2011 7:48 pm    Post subject: Reply with quote
You did not mask the widshield? Shocked
PostPosted: Sat May 14, 2011 7:53 pm    Post subject: Reply with quote
Looks like it has a big crack in it and probably needs replaced.
Engine bay looks good. I used to see a lot of that color with my last employer Very Happy
IROCDave
PostPosted: Sat May 14, 2011 8:12 pm    Post subject: Reply with quote
Looks like a good start, but needs some gloss black before putting together.
PostPosted: Sat May 14, 2011 8:38 pm    Post subject: Reply with quote
Yup yup
I'll bet.
Don't worry about that. The entire exterior will be gloss black. Wink
PostPosted: Sun May 15, 2011 9:59 am    Post subject: Reply with quote
Yup, it's an enginebay. Very Happy
Looks good dude.
PostPosted: Sun May 15, 2011 10:03 am    Post subject: Reply with quote
Good start, what's next Aaron? Very Happy
On a completely unrelated note, I like working with engines. And wiring. And electronics.
Also absolutely not related in any way whatsoever, Cows is pretty soon. I'll let you put the pieces of the puzzle together. Laughing
PostPosted: Sun May 15, 2011 10:23 am    Post subject: Reply with quote
That's all fine and good until you're messing around with something and happen to have dirty hands Wink My white engine bay isn't that white anymore.
PostPosted: Sun May 15, 2011 10:24 am    Post subject: Reply with quote
Looks many times better than it did when we pulled that nasty motor! Cool
PostPosted: Sun May 15, 2011 11:35 am    Post subject: Reply with quote
looks great! thats gunna be a nice ride Smile
-Donald
PostPosted: Sun May 15, 2011 12:24 pm    Post subject: Reply with quote
That was actually my goal here, Chris. I originally shot the thing gloss black, but then I sanded it down and went with the high-gloss grey. I figure I'll see everything easier, and it's easier to clean.
In an equally unrelated note, you got a PM! Very Happy
PostPosted: Sun May 15, 2011 1:50 pm    Post subject: Reply with quote
How did you prep the bay before spraying it?
PostPosted: Sun May 15, 2011 3:21 pm    Post subject: Reply with quote
Scrape off crud
Spray with degreaser (I used 409, but the Purple stuff or oven cleaner would have been better)
Hose out
Sand with 120 on areas with flaking/rust, sand the rest with 220
Degrease again
Hose out again, let dry overnight under fans
Spray with brake cleaner, let dry
2 coats primer about 10mins apart
2 coats color the same
I'm not a painter, but it worked, so... Shrug
