Posted: Sat May 14, 2011 7:13 pm Post subject: Whadya all think? |
"Light Machine Grey." I figure it's a Chevy, and this way I can see everything that inevitably leaks out of it.
Either way it's an improvement from before...
turbo_jimi Member
Posted: Sat May 14, 2011 7:21 pm Post subject: |
Looks clean. _________________
Posted: Sat May 14, 2011 7:48 pm Post subject: |
You did not mask the widshield?  |
Posted: Sat May 14, 2011 7:53 pm Post subject: |
| Xophertony wrote: | You did not mask the widshield?  |
Looks like it has a big crack in it and probably needs replaced.
Engine bay looks good. I used to see a lot of that color with my last employer  _________________ 92 Camaro
IROCDave Member
Posted: Sat May 14, 2011 8:12 pm Post subject: |
| Looks like a good start, but needs some gloss black before putting together. |
Posted: Sat May 14, 2011 8:38 pm Post subject: |
| Al Hasse wrote: | | Xophertony wrote: | You did not mask the widshield?  |
Looks like it has a big crack in it and probably needs replaced. |
| Al Hasse wrote: | Engine bay looks good. I used to see a lot of that color with my last employer  |
I'll bet.
| IROCDave wrote: | | needs some gloss black |
Don't worry about that. The entire exterior will be gloss black.  |
Posted: Sun May 15, 2011 9:59 am Post subject: |
Yup, it's an enginebay.
Looks good dude. _________________
Posted: Sun May 15, 2011 10:03 am Post subject: |
Good start, what's next Aaron?
On a completely unrelated note, I like working with engines. And wiring. And electronics.
Also absolutely not related in any way whatsoever, Cows is pretty soon. I'll let you put the pieces of the puzzle together.  _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun May 15, 2011 10:23 am Post subject: |
| Quote: | | "Light Machine Grey." I figure it's a Chevy, and this way I can see everything that inevitably leaks out of it. |
That's all fine and good until you're messing around with something and happen to have dirty hands My white engine bay isn't that white anymore. _________________
Posted: Sun May 15, 2011 10:24 am Post subject: |
Looks many times better than it did when we pulled that nasty motor!  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
popballz Member
Posted: Sun May 15, 2011 11:35 am Post subject: |
looks great! thats gunna be a nice ride  _________________ -Donald
Posted: Sun May 15, 2011 12:24 pm Post subject: |
| Quasi-Traction wrote: | That's all fine and good until you're messing around with something and happen to have dirty hands |
That was actually my goal here, Chris. I originally shot the thing gloss black, but then I sanded it down and went with the high-gloss grey. I figure I'll see everything easier, and it's easier to clean.
| Alphius wrote: | | I like working with engines. And wiring. And electronics. |
In an equally unrelated note, you got a PM!  |
Posted: Sun May 15, 2011 1:50 pm Post subject: |
| How did you prep the bay before spraying it? |
Posted: Sun May 15, 2011 3:21 pm Post subject: |
| RSFreak wrote: | | How did you prep the bay before spraying it? |
Scrape off crud
Spray with degreaser (I used 409, but the Purple stuff or oven cleaner would have been better)
Hose out
Sand with 120 on areas with flaking/rust, sand the rest with 220
Degrease again
Hose out again, let dry overnight under fans
Spray with brake cleaner, let dry
2 coats primer about 10mins apart
2 coats color the same
I'm not a painter, but it worked, so...  |
