SlackerTA Member
Posted: Tue Feb 15, 2011 1:40 pm Post subject: Hinge pin difficulty? |
Like many 3rd gens my T/As doors are sagging and I'm tired of it. How hard is it to install a new hinge pin kit? Any suggestions on what to get or where to get it? I've heard its easier if you have someone to help hold the door. _________________ '91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD |
Posted: Tue Feb 15, 2011 5:35 pm Post subject: |
I replaced one side when I replaced the door. As you can guess, much easier.
The other side was a bit of work. I still have yet to get that spring back in even with the cool tool....It just doesnt fit |
SlackerTA Member
Posted: Wed Feb 16, 2011 8:45 am Post subject: |
Thanks for the info, guys. That's exactly what I needed to know.  _________________ '91 Firebird - LO3, 700R4, 2.73 gears
'85 Trans Am - SOLD
'95 Z28 - SOLD |
Posted: Thu Feb 17, 2011 9:23 pm Post subject: |
also if you can't get a buddy to help ya hold up the door, and you happen to have some nylon rope or strap and a cherry-picker, you can use that to support the door.
IIRC, Xophertony did this when he replaced his hinge pins many years ago. _________________
popballz Member
Posted: Sun Feb 20, 2011 5:49 pm Post subject: |
| 91RSVert wrote: | I replaced one side when I replaced the door. As you can guess, much easier.
i'm rockin doors with no springs....
i used a come-a-long on the rafters in my garage. worked well but took me like 2.5 hours to get the pass pin out because it was rusted or somethin _________________ -Donald
IROCDave Member
Posted: Fri Feb 25, 2011 5:25 pm Post subject: |
| It's been along time but I vaguely remember doing this on my car. IIRC, I built a jig out of wood to hold the door at the correct elevation and in plane. It consisted of a couple of 4x6's, 1x4 and verticle 2x4's to hold the door upright. I got the door loose then slid the whole assembly away from the car. |
Posted: Sun Feb 27, 2011 7:15 pm Post subject: |
I just had someone else unbolt my door while I picked it up and set it on some sawhorses. Did the work and held it in place for the bolt jockey to hook 'er back up.
Didn't have any troubles with my spring things either. I think I used a crowbar to pry the spring and pop it into place. _________________ 84 Camaro Z28 - LS1/T56
