Posted: Sun Jan 02, 2011 7:33 pm Post subject: LED Opinions |
I have a strip of 6 LEDs left over from my brake light mod. I'm trying ideas on where to use them. I can only split them int groups of 3, so pretty limited. I thought about under the center vents where the really dim light is, which hardly ever works. Split in half and do the door handles like the 92.
I taped them up under the center vents and hooked a 9V battery. Looks OK to me, and not distracting to me as a driver, but to pull the effect off, I think the whole dash should be done.
 _________________ 92 Camaro
Posted: Sun Jan 02, 2011 8:07 pm Post subject: |
Kind of reminds me of a cop car.
Is there room to mount them to the bottom side of the door to illuminate the ground when the doors open? _________________
Posted: Sun Jan 02, 2011 9:15 pm Post subject: |
If the clearance is there between the door and GFX, that might be an idea for a 1-meter strip of white LEDs under each door. I suppose I'd hook them up to the door pin switch for the dome light. Now I've got to check for clearance, since I have new hinges, my doors don't rub on the GFX
Could also do red on the back edge of the door, kind of like some of the higher end luxury cars  |
Posted: Sun Jan 02, 2011 9:20 pm Post subject: |
use them for pimptastic door sills, ala AMG.
Matthew88M Member
Posted: Mon Jan 03, 2011 8:26 am Post subject: |
3 words
Lighted Scuff Plates  |
Posted: Mon Jan 03, 2011 12:58 pm Post subject: |
I'm thinking knight rider door handles _________________ 2008 GMC Z71
BigDaddyVu 12sec Club
Posted: Mon Jan 03, 2011 5:23 pm Post subject: |
above your crome tail pipes, under the trunk deck lighted when raised, above your fogs but hidden, under hood lighting. under your interior mirror, inside your outside mirrors. Just and idea for your romantic glow. _________________
Posted: Mon Jan 03, 2011 5:25 pm Post subject: |
Door jams lighted so nobody would hit your open door. _________________
Posted: Mon Jan 03, 2011 7:42 pm Post subject: |
Footwell accent lighting. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
IROCDave Member
Posted: Wed Jan 05, 2011 5:59 pm Post subject: |
| If you dont have the room on the bottom of the doors, recess them into the bottom of the arm rest. Trigger them with the door pins. |
Posted: Wed Jan 05, 2011 6:25 pm Post subject: |
Looks like there is room on the bottom of the door, just inside the weatherstrip. I think the inner door handles will be done with what I have left, 3 LEDs in each wired with the gauges lights. There were quite a few nice ideas that I might look into, possibly for both cars  |
