cooling issue
RK82
1982 Pontiac Trans Am
PostPosted: Wed Dec 22, 2010 5:04 pm    Post subject: cooling issue Reply with quote
well kind of a cooling issue, I want the car to run at 170-180 is where my butt dyno tells me the car runs best, but no-matter what I do it runs at 190-195 and feels kinda sluggish.
the cooling system is pretty much stock except for a mr. gasket 180 T-stat and maradyne texas twister fan.
anyone have any ideas, I've tried a few different things with same results, the only thing I haven't done is tried a 160 T-stat.
PostPosted: Wed Dec 22, 2010 5:34 pm    Post subject: Reply with quote
I've got a 180t-stat and a modded 350, stock fans and mine stays at 185 all day long.
Might think about gauge accuracy.
PostPosted: Wed Dec 22, 2010 7:53 pm    Post subject: Reply with quote
The gauge isn't gonna cause loss of power at higher temps, though. My guess would be low timing, or a lousy tune.
RK82
PostPosted: Thu Dec 23, 2010 9:20 am    Post subject: Reply with quote
I never thought of low timing I'll have check next time I fire it up but I think its set at 12* initial, 18* mechanical.
I forgot to mention above it also has a off-idle hesitation once it get up to 190, it dosen't do it at lower temps.
PostPosted: Thu Dec 23, 2010 1:42 pm    Post subject: Reply with quote
He did say butt dyno. Cars are always faster cold.
Are we dealing with EFI are carb here?
RK82
PostPosted: Thu Dec 23, 2010 2:46 pm    Post subject: Reply with quote
carb, Edelbrock 600
PostPosted: Thu Dec 23, 2010 5:21 pm    Post subject: Reply with quote
Aren't those carbs particularly susceptible to heat soak because of the position of the fuel bowls? Might be time for a nice phenolic spacer.
RK82
PostPosted: Thu Dec 23, 2010 5:38 pm    Post subject: Reply with quote
already have a 1" in there, I took it out the last few weeks I drove the car just to see, it seemed to have more grunt at higher RPMs but the temp issue was still there.
you think a 1/2" spacer would make a difference
PostPosted: Thu Dec 23, 2010 8:18 pm    Post subject: Reply with quote
What material is the spacer? Aluminum does nothing for heat soak.
RK82
PostPosted: Thu Dec 23, 2010 9:59 pm    Post subject: Reply with quote
its this one here
http://www.summitracing.com/parts/TRD-2382/
PostPosted: Fri Dec 24, 2010 3:11 pm    Post subject: Reply with quote
Plastic is better but phenolic is perfect.
Check timing again.
Make sure the coolant looks good too.
RK82
PostPosted: Fri Dec 24, 2010 3:46 pm    Post subject: Reply with quote
Check timing again.
I thought the one I bought was phenolic plastic? so the phenolic wood fiber ones are better?
I was looking at them but the thought of a hot intake, wood, and gas made me kinda nervous, I've always used a 1" spacer besides hood clearance would getting a 1/2" be better?
the coolants only a couple months old, and I'll play with the timing again.
PostPosted: Fri Dec 24, 2010 4:39 pm    Post subject: Reply with quote
The wood kind are fine. I ran a Summit 1/2" phenolic on the 390, and it helped a lot. I would have gone thicker, but that engine barely fits under the hood as it is.
RK82
PostPosted: Fri Dec 24, 2010 5:20 pm    Post subject: Reply with quote
ok, I think I'll try a 1/2" wood fiber spacer and a 160 T-stat, I figure with a 160 using the rule that thermostats work within a 12* +/- of what there rated at, it should run around 170 right where it likes it.
BluFbdy
PostPosted: Tue Dec 28, 2010 10:13 pm    Post subject: Reply with quote
not that anyone cares about it that much but your car will get crappy mileage, plus i THINK....dont quote me on this that the open/closed loop cutoff is around 170 ish, my car was going balistic when i got it up here from as cuz i had the 160*, down there it ran at around 180* but its obviously not as hot up here so it kept going thru the cycles and confusing itself, killing my gas mileage lol ive got a 190* in now and i sit aorund 200*, not great for power but its the winter time so im not too worried about it
PostPosted: Wed Dec 29, 2010 8:32 pm    Post subject: Reply with quote
Closed Loop Enable Temp Deg F : 104.45
Somehow I don't think his Edelbrock carb will mind too much though. Wink
The stock ECM needs the stock thermostat. If you are planning on keeping the EFI, you'd be better off in the long run to start burning chips, and then just run a proper stat instead of the emissions one. The car will go into closed loop, but it will still run rich as crap.
Also, I have found that 160* stats are a bit to low on even a carbed car around here. Never heat up, just sit at 150* all day. Cheap to try, though. Shrug
BluFbdy
PostPosted: Wed Dec 29, 2010 10:59 pm    Post subject: Reply with quote
I said don't quote me lol but yeah I had to get rid of my 160* because my car haaaaated it
RK82
PostPosted: Thu Dec 30, 2010 10:16 am    Post subject: Reply with quote
ya, no ECM in my car, I think it'll be ok Wink
PostPosted: Fri Dec 31, 2010 7:49 pm    Post subject: Reply with quote
You also got your heat to worry about. Is your heater working ok when the cars at 160ish?
RK82
PostPosted: Fri Dec 31, 2010 8:12 pm    Post subject: Reply with quote
my car doesn't have a heater in it.
