RK82 Member
1982 Pontiac Trans Am
Posted: Wed Dec 22, 2010 5:04 pm Post subject: cooling issue |
well kind of a cooling issue, I want the car to run at 170-180 is where my butt dyno tells me the car runs best, but no-matter what I do it runs at 190-195 and feels kinda sluggish.
the cooling system is pretty much stock except for a mr. gasket 180 T-stat and maradyne texas twister fan.
anyone have any ideas, I've tried a few different things with same results, the only thing I haven't done is tried a 160 T-stat. |
Posted: Wed Dec 22, 2010 5:34 pm Post subject: |
I've got a 180t-stat and a modded 350, stock fans and mine stays at 185 all day long.
Might think about gauge accuracy. _________________ A redline a day keeps the carbon away! |
Posted: Wed Dec 22, 2010 7:53 pm Post subject: |
| The gauge isn't gonna cause loss of power at higher temps, though. My guess would be low timing, or a lousy tune. |
RK82 Member
Posted: Thu Dec 23, 2010 9:20 am Post subject: |
| aaron_sK wrote: | | The gauge isn't gonna cause loss of power at higher temps, though. My guess would be low timing, or a lousy tune. |
I never thought of low timing I'll have check next time I fire it up but I think its set at 12* initial, 18* mechanical.
I forgot to mention above it also has a off-idle hesitation once it get up to 190, it dosen't do it at lower temps. |
Posted: Thu Dec 23, 2010 1:42 pm Post subject: |
He did say butt dyno. Cars are always faster cold.
Are we dealing with EFI are carb here? _________________ A redline a day keeps the carbon away! |
RK82 Member
Posted: Thu Dec 23, 2010 2:46 pm Post subject: |
| carb, Edelbrock 600 |
Posted: Thu Dec 23, 2010 5:21 pm Post subject: |
| Aren't those carbs particularly susceptible to heat soak because of the position of the fuel bowls? Might be time for a nice phenolic spacer. |
RK82 Member
Posted: Thu Dec 23, 2010 5:38 pm Post subject: |
| aaron_sK wrote: | | Aren't those carbs particularly susceptible to heat soak because of the position of the fuel bowls? Might be time for a nice phenolic spacer. |
already have a 1" in there, I took it out the last few weeks I drove the car just to see, it seemed to have more grunt at higher RPMs but the temp issue was still there.
you think a 1/2" spacer would make a difference |
Posted: Thu Dec 23, 2010 8:18 pm Post subject: |
| What material is the spacer? Aluminum does nothing for heat soak. |
RK82 Member
Posted: Fri Dec 24, 2010 3:11 pm Post subject: |
Plastic is better but phenolic is perfect.
Check timing again.
Make sure the coolant looks good too. _________________ A redline a day keeps the carbon away! |
RK82 Member
Posted: Fri Dec 24, 2010 3:46 pm Post subject: |
| Twilightoptics wrote: | Plastic is better but phenolic is perfect.
Check timing again.
Make sure the coolant looks good too. |
I thought the one I bought was phenolic plastic? so the phenolic wood fiber ones are better?
I was looking at them but the thought of a hot intake, wood, and gas made me kinda nervous, I've always used a 1" spacer besides hood clearance would getting a 1/2" be better?
the coolants only a couple months old, and I'll play with the timing again. |
Posted: Fri Dec 24, 2010 4:39 pm Post subject: |
| The wood kind are fine. I ran a Summit 1/2" phenolic on the 390, and it helped a lot. I would have gone thicker, but that engine barely fits under the hood as it is. |
RK82 Member
Posted: Fri Dec 24, 2010 5:20 pm Post subject: |
| ok, I think I'll try a 1/2" wood fiber spacer and a 160 T-stat, I figure with a 160 using the rule that thermostats work within a 12* +/- of what there rated at, it should run around 170 right where it likes it. |
BluFbdy Member
Posted: Tue Dec 28, 2010 10:13 pm Post subject: |
not that anyone cares about it that much but your car will get crappy mileage, plus i THINK....dont quote me on this that the open/closed loop cutoff is around 170 ish, my car was going balistic when i got it up here from as cuz i had the 160*, down there it ran at around 180* but its obviously not as hot up here so it kept going thru the cycles and confusing itself, killing my gas mileage lol ive got a 190* in now and i sit aorund 200*, not great for power but its the winter time so im not too worried about it _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Wed Dec 29, 2010 8:32 pm Post subject: |
| BluFbdy wrote: | | the open/closed loop cutoff is around 170 |
Closed Loop Enable Temp Deg F : 104.45
Somehow I don't think his Edelbrock carb will mind too much though.
The stock ECM needs the stock thermostat. If you are planning on keeping the EFI, you'd be better off in the long run to start burning chips, and then just run a proper stat instead of the emissions one. The car will go into closed loop, but it will still run rich as crap.
Also, I have found that 160* stats are a bit to low on even a carbed car around here. Never heat up, just sit at 150* all day. Cheap to try, though.  |
BluFbdy Member
Posted: Wed Dec 29, 2010 10:59 pm Post subject: |
I said don't quote me lol but yeah I had to get rid of my 160* because my car haaaaated it _________________ If you expect a kick to the balls and get a slap to the face its still a victory
RK82 Member
Posted: Thu Dec 30, 2010 10:16 am Post subject: |
| aaron_sK wrote: | | BluFbdy wrote: | | the open/closed loop cutoff is around 170 |
ya, no ECM in my car, I think it'll be ok  |
fiveoformula Member
Posted: Fri Dec 31, 2010 7:49 pm Post subject: |
| You also got your heat to worry about. Is your heater working ok when the cars at 160ish? |
RK82 Member
Posted: Fri Dec 31, 2010 8:12 pm Post subject: |
| my car doesn't have a heater in it. |
