difference in injector lengths
IROCDave
PostPosted: Thu Nov 25, 2010 9:15 am    Post subject: difference in injector lengths Reply with quote
For TPI settups that do not have a fixed fuel rail this doesnt matter, but for mine the shorter injectors wont seel. [imgPhotobucket][/img]
From left to right, Bosche, SVO red top and LS1.
PostPosted: Thu Nov 25, 2010 10:07 am    Post subject: Reply with quote
Looks like a slight difference.. measure o-ring to o-ring.. not the tips.
IROCDave
PostPosted: Fri Nov 26, 2010 9:55 am    Post subject: Reply with quote
The distance you see from tip to tip is the same as O-ring to O-ring. The LS1 injector is almost a 1/4" shorter than the Bosche and the SVO is about 3/16 shorter.
PostPosted: Fri Nov 26, 2010 10:07 am    Post subject: Reply with quote
The LS and SVO look incredibly close o-ring to o-ring
PostPosted: Fri Nov 26, 2010 4:46 pm    Post subject: Reply with quote
There doesnt look like an 1/8 difference o-ring to o-ring in that pic. The plastic tip doesnt do any sealing.
IROCDave
PostPosted: Mon Nov 29, 2010 6:05 pm    Post subject: Reply with quote
The difference between each injector O-ring - O-ring is about 1/8". That is enough to have a leak on the T-Ram.
