Gears in stock T5
nonsensekid20
PostPosted: Wed Nov 10, 2010 11:58 am    Post subject: Gears in stock T5 Reply with quote
What size gears were stock in the T5 for a 91?
PostPosted: Wed Nov 10, 2010 12:02 pm    Post subject: Reply with quote
huh?
nonsensekid20
PostPosted: Wed Nov 10, 2010 12:14 pm    Post subject: Reply with quote
Oops, lol. I meant the rear end. 91 RS.
PostPosted: Wed Nov 10, 2010 12:18 pm    Post subject: Reply with quote
Prob 3.42
PostPosted: Wed Nov 10, 2010 4:16 pm    Post subject: Reply with quote
if it is a TBI car, and a manual, it should be 3.08 from the factory.
BluFbdy
PostPosted: Wed Nov 10, 2010 6:33 pm    Post subject: Reply with quote
are you looking to switch them out? or was this a curiosity thing?
nonsensekid20
PostPosted: Wed Nov 10, 2010 8:49 pm    Post subject: Reply with quote
Just curious. I've driven that car about 7 miles. lol. Before the engine swap it was a 305 TBI. 5 speed.
PostPosted: Wed Nov 10, 2010 8:52 pm    Post subject: Reply with quote
Get a jack and count it out. Only way to know for sure what's in there without pulling it apart. Jon will tell you about how stuff gets changed out for stupid reasons. Razz
PostPosted: Wed Nov 10, 2010 9:36 pm    Post subject: Reply with quote
Yeah, you really could have anything in that axle. It's not necessarily stock.
Lift the back of the car and put the trans in neutral. If you have posi then both tires should rotate the same direction and of equal amount. If you have limited slip or open differential then one wheel spins in the opposite direction as the other and you will need to chalk one wheel so it won't spin (and to make the driveshaft spin). Rotate the tire 10 times and count the number of revolutions of the driveshaft.
Gear Ratio = (driveshaft rotations) / (wheel rotations)
You need to multiply by 2 if you chalked one wheel.
The more brainless you can make this the more accurate you will be. I put a piece of tape in the 6 o'clock position on the driveshaft and do the same on the wheel that I'm going to rotate. (remember, you can move tape to line things up again Wink) I also keep two columns of data on a piece of paper and place a hash mark in the appropriate column each time the driveshaft or wheel goes a full revolution. If you are uber accurate then you can just spin the wheel once. I'm not that good. Spinning the wheel 10 times improves accuracy. You're trying to measure a small fraction of a difference in gear ratios so being off by a little bit can make things questionable. I used this procedure on my Camaro and was accurate within 0.01.
BluFbdy
PostPosted: Wed Nov 10, 2010 10:52 pm    Post subject: Reply with quote
The only exception to that is if you're running a zexel torsen, they won't run the worm gear up enough by just rotating it in which case the only thing you can do to be TOTALLY sure is to open it up and have a look, check for posi and count the ring and pinion while you're in there driven divided by drive (ring gear divided by pinion) and you have your ratio
On a side note I've got a set of richmond gears with like 70 miles on them, 3.23 if you're interested, I pulled them outta my truck and swapped to a 4.10 and they were cleaned off and put back in their box if you're interested
PostPosted: Thu Nov 11, 2010 4:59 am    Post subject: Reply with quote
No, the Torsen is no different than anything else. It is gear driven and behaves like an open diff when you rotate it.
I just went through this in a few weeks ago on my 2001 SS. Wink
BluFbdy
PostPosted: Thu Nov 11, 2010 5:29 pm    Post subject: Reply with quote
Yeah that's what I meant, they're the most deceptive unit cuz you can tell by just spinning the tires in the air, we had that issue with my friends gta it had a torsen, I checked it by jackin up the axle and spinning it, looked like an open diff but I could swear up and down both tires were spinning when I burnt out, popped the cover and bam zexel torsen lol sneaky pricks
nonsensekid20
PostPosted: Fri Nov 12, 2010 8:59 am    Post subject: Reply with quote
From what I remember, last time I checked I spun the right wheel, but the left didn't spin. hmm..
Does anyone have a posi unit?
BluFbdy
PostPosted: Fri Nov 12, 2010 11:48 am    Post subject: Reply with quote
I've got one in a box
PostPosted: Fri Nov 12, 2010 3:41 pm    Post subject: Reply with quote
Something is going to spin, whether it's the other wheel or the driveshaft. The reason I suggest to chalk the other wheel is because if it does spin at all it slows down the driveshaft and ruins your calculations.
nonsensekid20
PostPosted: Fri Nov 12, 2010 7:43 pm    Post subject: Reply with quote
Wanna trade for a non posi? lol.
BluFbdy
PostPosted: Sat Nov 13, 2010 8:33 pm    Post subject: Reply with quote
I've been sitting on my torsen unit for a while I haven't gotten the axles fr it, just search ebay for them, don't get a gov-loc unless you feel like re doing it later I blew thru 3 of them before I gave up and put an open unit in there, I pickied up the torsen hoping to swap it but you need the proper series gears and a new set of axles becaus e the spline count is different
PostPosted: Sun Nov 14, 2010 8:08 am    Post subject: Reply with quote
The Torsen has 28 spline input. 1990 and up axles have 28 spline axle shafts. You only need to swap axle shafts if you have an older car.
The Torsen comes with both 2-series and 3-series gears. Which do you need? I am sitting on a 2-series right now. If you're sitting on a 3-series that you can't use, then I might work a straight up trade for my 2-series and in the end we're both happy. Wink
BluFbdy
PostPosted: Sun Nov 14, 2010 11:21 am    Post subject: Reply with quote
Correct lol but if I had a 92 I would have had most of my body work done already lol and I would have lucked out on the axles honestly tho id still replace mine if I had the 28's but I'm ocd with doing new parts because in my experience if you want part A, you need parts B thru D to either compliment it or to even install it lol
PostPosted: Mon Nov 15, 2010 10:54 am    Post subject: Reply with quote
I didn't follow anything you said, but I'll take that as a "not interested."
