		'92 camaro boss Member
   1992  Chevrolet  Camaro RS
				 Posted: Wed Nov 03, 2010 10:59 pm    Post subject: RPO Code |
				I'm not as familiar as I once was with the RPO codes.
But my grandpa was looking at a 92 Z-28, i know the 350's only came with auto's (which this one is) but what's the code to ID a factory 350 car? also the all disk break option? |
   1990  Chevrolet  Camaro RS
				 Posted: Wed Nov 03, 2010 11:00 pm    Post subject:  |
				| The VIN should indicated the engine from the factory.  No need to even look for an RPO sheet if all you want to know is the factory engine. |
				 Posted: Wed Nov 03, 2010 11:01 pm    Post subject:  |
				| What letter should i look for at one space (don't have my camaro book anymore) |
		91camaro_rs Member
   1991  Chevrolet  Camaro RS
				 Posted: Wed Nov 03, 2010 11:11 pm    Post subject:  |
				8th digit should be the number 8  for a 350 car _________________
				 Posted: Wed Nov 03, 2010 11:12 pm    Post subject:  |
				| appreciate it, thank you. |
   1991  Pontiac  Trans Am
				 Posted: Wed Nov 03, 2010 11:58 pm    Post subject:  |
				Just for future reference, L98 and B2L are the RPO codes you'd be looking for. _________________
 	  | Quote: | 	 		  | Sometimes I actually think I'm slightly retarded in the mouth. |
   1989  Chevrolet  Camaro RS
				 Posted: Thu Nov 04, 2010 5:54 pm    Post subject:  |
				L98 is only aluminum heads (Corvette motor), right? I've only heard B2L for a Camaro.    _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
   1989  Pontiac  GTA
				 Posted: Thu Nov 04, 2010 6:40 pm    Post subject:  |
				L98 was the designation for both iron and aluminum heads. IIRC first year TPI vettes were also iron head. Aluminum started sometime in the second year of the run.
				 Posted: Thu Nov 04, 2010 7:12 pm    Post subject:  |
				 	  | Schultzy89GTA wrote: | 	 		  L98 was the designation for both iron and aluminum heads. IIRC first year TPI vettes were also iron head. Aluminum started sometime in the second year of the run.
Really? I didn't think the 'Vettes got the aluminum heads until the 86-87 changeover to centerbolt heads, and 1pc rear main.
IIRC TPI started in the corvette in 1984. Camaro got it in 85. _________________
   1989  Pontiac  GTA
				 Posted: Thu Nov 04, 2010 7:21 pm    Post subject:  |
				84 was cross-fire not TPI. 85 had L98, iron heads. Aluminum head L98 started somewhere in the middle of 86 run. Aluminum head L98 was only on vettes.
				 Posted: Thu Nov 04, 2010 8:35 pm    Post subject:  |
				For the birds/camaros when you got L98 it automagically meant you got the code B2L (which in our case, meant iron heads).
Now this is obviously hearsay since I've never owned a 350 before.   _________________
				 Posted: Fri Nov 05, 2010 4:11 am    Post subject:  |
				I thought there was some GM aluminum permiter bolt heads that got put on vettes? _________________ 2008 GMC Z71
   1987  Pontiac  Formula
				 Posted: Fri Nov 05, 2010 1:42 pm    Post subject:  |
				 	  | 91RSVert wrote: | 	 		  | I thought there was some GM aluminum permiter bolt heads that got put on vettes? |
I remember that too.. Not entirely positive but I think the aluminum L98s were perimeter bolt.. and stayed that way in the vette til the lt1 came out. |
   1989  Pontiac  GTA
				 Posted: Fri Nov 05, 2010 2:19 pm    Post subject:  |
				Not positive on this one but thought that all of the L98 aluminum heads were center bolt but the intakes had the old intake bolt angles. Pretty sure that is the difference between the corvette TPI base and the F body TPI base.
				 Posted: Sat Nov 06, 2010 10:38 am    Post subject:  |
				| Well the car was junk, tired 305. smoked like crazy. trans was gone. |
