RPO Code
'92 camaro boss
PostPosted: Wed Nov 03, 2010 10:59 pm    Post subject: RPO Code Reply with quote
I'm not as familiar as I once was with the RPO codes.
But my grandpa was looking at a 92 Z-28, i know the 350's only came with auto's (which this one is) but what's the code to ID a factory 350 car? also the all disk break option?
PostPosted: Wed Nov 03, 2010 11:00 pm    Post subject: Reply with quote
The VIN should indicated the engine from the factory. No need to even look for an RPO sheet if all you want to know is the factory engine.
'92 camaro boss
PostPosted: Wed Nov 03, 2010 11:01 pm    Post subject: Reply with quote
What letter should i look for at one space (don't have my camaro book anymore)
91camaro_rs
PostPosted: Wed Nov 03, 2010 11:11 pm    Post subject: Reply with quote
8th digit should be the number 8 for a 350 car
'92 camaro boss
PostPosted: Wed Nov 03, 2010 11:12 pm    Post subject: Reply with quote
appreciate it, thank you.
PostPosted: Wed Nov 03, 2010 11:58 pm    Post subject: Reply with quote
Just for future reference, L98 and B2L are the RPO codes you'd be looking for.
PostPosted: Thu Nov 04, 2010 5:54 pm    Post subject: Reply with quote
L98 is only aluminum heads (Corvette motor), right? I've only heard B2L for a Camaro. Confused
PostPosted: Thu Nov 04, 2010 6:40 pm    Post subject: Reply with quote
L98 was the designation for both iron and aluminum heads. IIRC first year TPI vettes were also iron head. Aluminum started sometime in the second year of the run.
PostPosted: Thu Nov 04, 2010 7:12 pm    Post subject: Reply with quote
Really? I didn't think the 'Vettes got the aluminum heads until the 86-87 changeover to centerbolt heads, and 1pc rear main.
IIRC TPI started in the corvette in 1984. Camaro got it in 85.
PostPosted: Thu Nov 04, 2010 7:21 pm    Post subject: Reply with quote
84 was cross-fire not TPI. 85 had L98, iron heads. Aluminum head L98 started somewhere in the middle of 86 run. Aluminum head L98 was only on vettes.
PostPosted: Thu Nov 04, 2010 8:35 pm    Post subject: Reply with quote
For the birds/camaros when you got L98 it automagically meant you got the code B2L (which in our case, meant iron heads).
Now this is obviously hearsay since I've never owned a 350 before. Very Happy
PostPosted: Fri Nov 05, 2010 4:11 am    Post subject: Reply with quote
I thought there was some GM aluminum permiter bolt heads that got put on vettes?
PostPosted: Fri Nov 05, 2010 1:42 pm    Post subject: Reply with quote
I remember that too.. Not entirely positive but I think the aluminum L98s were perimeter bolt.. and stayed that way in the vette til the lt1 came out.
PostPosted: Fri Nov 05, 2010 2:19 pm    Post subject: Reply with quote
Not positive on this one but thought that all of the L98 aluminum heads were center bolt but the intakes had the old intake bolt angles. Pretty sure that is the difference between the corvette TPI base and the F body TPI base.
'92 camaro boss
PostPosted: Sat Nov 06, 2010 10:38 am    Post subject: Reply with quote
Well the car was junk, tired 305. smoked like crazy. trans was gone.
