Something no one ever thought I'd do!
PostPosted: Mon Jun 28, 2010 6:33 pm    Post subject: Something no one ever thought I'd do! Reply with quote
I Put A/C INTO something.
I have access to Freon and the machine at work and free conversion fittings. So I said screw it! And I put the A/C in. Few loose ends to tie up.
I also put a 120 amp Izuzu alternator on. It's massive. I have yet to change the pulley to my dual belt pulley. On the list. Makes the motor look even smaller with all that stuff in there.
PostPosted: Mon Jun 28, 2010 6:59 pm    Post subject: Reply with quote
Wow! Old age setting in early? Razz
But yes.. I like my A/C! If it slows you down, ADD MORE POWER!
PostPosted: Mon Jun 28, 2010 7:01 pm    Post subject: Reply with quote
There is an engine in there? Razz
AC is comfy eh lad? Cool
Laughing
PostPosted: Mon Jun 28, 2010 7:02 pm    Post subject: Reply with quote
Your getting soft, old man.
PostPosted: Mon Jun 28, 2010 7:04 pm    Post subject: Reply with quote
hmmm, this opens more doors. Now you need an 'old man bike' and come with me and John on this year's motorcycle trek!
PostPosted: Mon Jun 28, 2010 7:05 pm    Post subject: Reply with quote
I figure I have to ditch the clutch fan to make the power back. Especially for the draw of that alternator!
PostPosted: Mon Jun 28, 2010 7:13 pm    Post subject: Reply with quote
So when the a/c kicks in does the rx7 do a time warp backward?? Maybe mazda should have added another rotor to pump the ac! Laughing
PostPosted: Mon Jun 28, 2010 7:15 pm    Post subject: Reply with quote
Do your lights dim at idle? As high speed as that engine goes, the alternator must darn near shut off at idle in order to keep the alternator speed in check at the top end. Just kind of wondering how that works.
PostPosted: Mon Jun 28, 2010 7:51 pm    Post subject: Reply with quote
Regulator does all the work. Rpms really don't matter. The biggest thing to watch out for is pulley size. Alternators are made to spin at a certain RPM themselves to function. We put a draw on the alt and it put out 120 amps at idle. The motor only revs to 7. Not much more than your average import 4cyl.
It's an Izuzu alternator and they rev to 3500. Works great. Parts are the same as a car.
Haven't charged the A/C yet. I'm going to purge the system with nitrogen and check leaks. Then I'll run it with the old filter/dryer and expansion valve for a bit to collect all the junk. Then I'll put new ones in once it's all good.
PostPosted: Mon Jun 28, 2010 8:03 pm    Post subject: Reply with quote
Do you have a leak detector that actually works like it should? We've had a few, and as far as i'm concerned they've all been garbage. You could probably feel the leak as easily as find it with our detector. Sad
PostPosted: Mon Jun 28, 2010 8:18 pm    Post subject: Reply with quote
Ours is over sensative it seems. I've also got nitrogen to pump through the system at high pressures.
PostPosted: Mon Jun 28, 2010 8:20 pm    Post subject: Reply with quote
Nitrogen would be nice. Is it as sensitive or more so using it? I've basically gotta charge it and look.
PostPosted: Mon Jun 28, 2010 8:29 pm    Post subject: Reply with quote
That's what you do with the nitrogen but it's cheaper and you can crank up the pressure to REALLY check. Plus it helps high pressure blow out the system.
PostPosted: Mon Jun 28, 2010 8:36 pm    Post subject: Reply with quote
Thanks, with the new boss there's at least a chance to upgrade some equipment once in awhile. So its good to hear what works for someone else.
PostPosted: Tue Jun 29, 2010 6:52 pm    Post subject: Reply with quote
A/C BLOWS COLD!!!!!!!!!!!!!!!!!!!!!!
Get to play with the pressures once it get's warmer out. Got all the electrical and the carb idle diaphram hooked up.
No idea what the high pressure switch cuts out at, or what the pressures are supposed to be. Couldn't even find accurate info on how much to charge the system which so I went with Forum Info for the fill lol.
PostPosted: Tue Jun 29, 2010 7:15 pm    Post subject: Reply with quote
pffft ... don't need no stinking instructions
Thumbs up
PostPosted: Tue Jun 29, 2010 8:29 pm    Post subject: Reply with quote
If its cold its working! Laughing
Does that system use an orifice tube or valve?
PostPosted: Tue Jun 29, 2010 8:44 pm    Post subject: Reply with quote
Expansion Valve.
I have a new one to put in at some point. Also need to find someone that has a Filter/Dryer. Wanted to run the system with the old stuff for a while to get all the old contaminants contained before putting the new parts in. Give it a few weeks.
Doesn't have a defrost on switch, which is a bummer.
PostPosted: Tue Jun 29, 2010 8:54 pm    Post subject: Reply with quote
Can you adjust the valve for pressure? I've never tried it, but read on the truck board where those guys have messed with the pressures for better cooling. I used a variable orifice in the formy and it really worked well. Speaking of which.. formy a/c is kaput for some reason at the moment.
