MrMike98 Member
Posted: Sat Jun 05, 2010 5:24 pm Post subject: Lower control arm relocation brackets-Yes or NO. |
i have heard good and bad.
this would be for a driver and not motocross, maybe 1 or 2 times down the 1/4.
i have the brackets there just not installed..
that leads into........
were/who is a recommended welder for installion of LCRB and weld in subframes, might as well do it all at once?????
thanks for the help, i hope i can return the favor sometime.
Mike |
Posted: Sat Jun 05, 2010 6:41 pm Post subject: |
It depends on your car. You want your LCA's to be paralell to the ground, or the axle side of the mount just slightly lower than the body side.
If you get too extreme away from that, you start having roll steer issues, or wheel hop issues, depending on which direction you are off.
If you are lowering the car, you will likely need them, but usualy only the first hole, you only really IMHO need the lower hole if your car is very low to the ground.
--John |
Posted: Sat Jun 05, 2010 7:55 pm Post subject: |
I have heard they help on wheelhop issues on drag racing.
My two cars have/are lowered and never had any installed. Something I would like to do, but other things are higher on the list. _________________ 2008 GMC Z71
Posted: Sun Jun 06, 2010 11:29 am Post subject: |
I had a buddy in Tacoma who used to make them. He swore by them. Unfortunately he is out of the 3rdgen business these days.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Sun Jun 06, 2010 10:31 pm Post subject: |
Late to the party but I noticed a significant difference with the brackets vs without. _________________
Posted: Mon Jun 07, 2010 5:45 am Post subject: |
+1 For the brackets. A must with any lowered car also. _________________ A redline a day keeps the carbon away! |
Outlaw28 Member
Posted: Tue Jun 08, 2010 7:52 pm Post subject: |
| +3 they made a big difference for me too |
turbo_jimi Member
Posted: Wed Jun 09, 2010 2:54 pm Post subject: |
I have Lakewood LCAs...i think they're cool, but my car is slow, so I can't tell a difference.  _________________
