Lower control arm relocation brackets-Yes or NO.
MrMike98
PostPosted: Sat Jun 05, 2010 5:24 pm    Post subject: Lower control arm relocation brackets-Yes or NO. Reply with quote
i have heard good and bad.
this would be for a driver and not motocross, maybe 1 or 2 times down the 1/4.
i have the brackets there just not installed..
that leads into........
were/who is a recommended welder for installion of LCRB and weld in subframes, might as well do it all at once?????
thanks for the help, i hope i can return the favor sometime.
Mike
PostPosted: Sat Jun 05, 2010 6:41 pm    Post subject: Reply with quote
It depends on your car. You want your LCA's to be paralell to the ground, or the axle side of the mount just slightly lower than the body side.
If you get too extreme away from that, you start having roll steer issues, or wheel hop issues, depending on which direction you are off.
If you are lowering the car, you will likely need them, but usualy only the first hole, you only really IMHO need the lower hole if your car is very low to the ground.
--John
PostPosted: Sat Jun 05, 2010 7:55 pm    Post subject: Reply with quote
I have heard they help on wheelhop issues on drag racing.
My two cars have/are lowered and never had any installed. Something I would like to do, but other things are higher on the list.
PostPosted: Sun Jun 06, 2010 11:29 am    Post subject: Reply with quote
I had a buddy in Tacoma who used to make them. He swore by them. Unfortunately he is out of the 3rdgen business these days. Sad
PostPosted: Sun Jun 06, 2010 12:17 pm    Post subject: Reply with quote
Relocation brackets are a must if your car is lowered. Have to keep those LCA's level.
PostPosted: Sun Jun 06, 2010 10:31 pm    Post subject: Reply with quote
Late to the party but I noticed a significant difference with the brackets vs without.
PostPosted: Mon Jun 07, 2010 5:45 am    Post subject: Reply with quote
+1 For the brackets. A must with any lowered car also.
Outlaw28
PostPosted: Tue Jun 08, 2010 7:52 pm    Post subject: Reply with quote
+3 they made a big difference for me too
PostPosted: Wed Jun 09, 2010 2:54 pm    Post subject: Reply with quote
I have Lakewood LCAs...i think they're cool, but my car is slow, so I can't tell a difference. Laughing
