Looking For LSx
Goto page Previous  1, 2
ChrisB
PostPosted: Fri Apr 09, 2010 7:15 pm    Post subject: Reply with quote
ls1tech should have all the info you need.
Junkyards are likely to have more trucks, suvs etc with 5.3s and 6.0s than fbodies/vettes etc with ls1/ls2/6/7 etc
91 Z28
PostPosted: Fri Apr 09, 2010 7:16 pm    Post subject: Reply with quote
Those 5.3's have a really big problem with oil consumption. 2 Qt's per 3,000 miles is deemed acceptable by GM. They're doing a oil consumption study right now to try and figure out a remedy to it.
ChrisB
PostPosted: Fri Apr 09, 2010 7:17 pm    Post subject: Reply with quote
Most ls1s eat a quart every 3k, whats another quart? lol
91 Z28
PostPosted: Fri Apr 09, 2010 7:52 pm    Post subject: Reply with quote
Hmm never heard about any consumption issues. All the ones I've changed oil in had been perfect full at 3k and higher with synth. Owners never mentioned anything.
PostPosted: Fri Apr 09, 2010 8:17 pm    Post subject: Reply with quote
LS7 is crazy expensive. You could do more and have less invested if you built up a basic LS1 or LS2.
I assume you want aluminum for weight reduction and handling for turns. If you just want a drag car then look closer at an 6.0L iron truck block. You can drop the Caddy 6.2L heads on it and basically have a LS6 engine on the cheap, but with a stronger foundation that can be built for more power. You could make a 427 stroker out of the truck block and start making serious power.
Leejo2005
PostPosted: Fri Apr 09, 2010 9:02 pm    Post subject: Reply with quote
I saw a couple of complete LS1 setups for sale at the swap meet today ranging from $2,500-3,500. 20K-80k miles on them.
PostPosted: Fri Apr 09, 2010 9:33 pm    Post subject: Reply with quote
GM thinks it may have something to do with the pistons/rings. Once they figure out the issue there may be a recall. While we're on the note of recalls, there may be one soon for LS3 equipped 5th gens, every single one we've had in for service at the dealership has had oil leaks at the oil pan gasket.
PostPosted: Fri Apr 09, 2010 9:34 pm    Post subject: Reply with quote
That's really only a problem near redline. Very Happy Steve mentioned that at Dyno that it's fairly normal and most people do the LS6 valley cover which has the pcv integrated in addition to the catch can.
I've done just about 9k on my 5.3 swap and I'm about a quart low just about to do another oil change. It's the same consumption my 305 had (a quart an oil change) but it's not from leaking, it sucks it through the intake at high rpms.
PostPosted: Fri Apr 09, 2010 9:35 pm    Post subject: Reply with quote
Spikeophant wrote:
You can get power like an LS out of a standard 350. I have a buddy that has a box van my dad and I are painting. He's got a 350 for it we had dyno'd after building that puts 650 down at the crank, natrually aspirated. It does have a custom ground cam in it though. I'm headed out to the shop on Sunday, I'll see if I can get specs on that cam, etc, in case anyone is intersted. I'm pretty sure the cam was from Crane. Not 100% on that though. What's funny about that engine, and van, is it's a work van, not even to haul his cars around. He plans to drive it daily for work, should be interesting. This guy had an Isuzu diesel box van he decided was too slow and propane injected, blew it up the first time he hit the switch. That thing was not a very fun rebuild....
Laughing
650 hp at what, 9000 rpm.
Gonna be quite the box truck
Spikeophant
1986 Chevrolet Camaro IROC-Z
PostPosted: Sat Apr 10, 2010 6:19 am    Post subject: Reply with quote
Don't want a drag car, not really into drag racing. I'm more of a road race person. So aluminum is ideal. What swap meet were those LS1's at?
1986 Camaro Z-28 IROC-Z 350 swap
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
Leejo2005
PostPosted: Sat Apr 10, 2010 7:27 am    Post subject: Reply with quote
The Portland swap meet, it's at PIR/Expo Center. It's $7 to get in, and ends tomorrow evening.
There were a few inside the buildings themselves and at least one out front. They all were fully assembled and with wiring harness. I know one was from a 99 Trans Am and another from a 2002 SS. One of them came with a 4L60E aswell.
2010 Cobalt LT
1999 Taurus SHO
1974 F-250 460
1967 Satellite Sport 383
PostPosted: Sat Apr 10, 2010 8:02 am    Post subject: Reply with quote
So thats what I can expect?! Shocked
PostPosted: Sat Apr 10, 2010 12:44 pm    Post subject: Reply with quote
Unless you change the front timing cover gasket and oilpan gasket, yeah. It'll leak a qt every oil change. Smile
Jason_Culbertson
1982 Pontiac Trans Am
PostPosted: Sat Apr 10, 2010 2:13 pm    Post subject: Reply with quote
man i hope you find all the parts you need and the build go's well Smile. when i first got my T/A i wanted to do a 383 stroker but as soon as a seen a LS1 swaped T/A it changed my mind Shocked
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
View user's profile Send private message Visit poster's website MSN Messenger
Page 2 of 2
