Power Hatch Pulldown
Spikeophant
1986 Chevrolet Camaro IROC-Z
PostPosted: Tue Apr 06, 2010 7:14 am    Post subject: Power Hatch Pulldown Reply with quote
Hey guys,
I have a power hatch pulldown, well, at least the motor is in there. If I plug it in it turns on as well. I want to fix this, any sticky's or anything I missed on these? My hatch always looks like it's popped since the pulldown doesn't work, and the latch is stuck in the up position.
1986 Camaro Z-28 IROC-Z 350 swap
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Tue Apr 06, 2010 7:30 am    Post subject: Reply with quote
http://www.top-downsolutions.com/index.php?cPath=22
You'll have to look at it, and see what is broken. I would guess the slides are knackered, but you'll have to see just what condition stuff is in.
Spikeophant
PostPosted: Tue Apr 06, 2010 7:49 am    Post subject: Reply with quote
So if I buy that deluxe pulldown repair kit on there I should have everything I need to fix it? I just looked at it again, and there's a green ribbon of wire coming off that's cut, but if I plug the thing in it turns on. I'm guessing maybe a bit of wiring, that kit, and all should be good. Thanks man.
PostPosted: Tue Apr 06, 2010 7:51 am    Post subject: Reply with quote
it sounds like your motor is ok, if it turns, you may just need the sliders, and maybe the gear-screw. The deluxe kit includes a new motor.
That is why I suggest digging into it, to try to see if you can figure out what is going on.
The ribbon cable probably got pulled, because it is stuck in the up-possition. So, as soon as you plug it in, it tries to close itself.
Spikeophant
PostPosted: Tue Apr 06, 2010 8:22 am    Post subject: Reply with quote
Cool, I'll look back there again after work, I'm hoping it stops snowing at some point, it's cold and lame here right now. Fortunately it's not so much snow I can't drive the Camaro. Wink
91camaro_rs
PostPosted: Tue Apr 06, 2010 4:57 pm    Post subject: Reply with quote
i called the guy at top-down solutions he walked me through everything i needed to do to figure out what was wrong with mine, it ended up being the reversing switch, got a new one...works great now!
