Spikeophant Member
Joined: 12 Mar 2010 Posts: 164 Location: Bend, Oregon
1986 Chevrolet Camaro IROC-Z
Posted: Tue Apr 06, 2010 7:14 am Post subject: Power Hatch Pulldown |
Hey guys,
I have a power hatch pulldown, well, at least the motor is in there. If I plug it in it turns on as well. I want to fix this, any sticky's or anything I missed on these? My hatch always looks like it's popped since the pulldown doesn't work, and the latch is stuck in the up position. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Spikeophant Member
Posted: Tue Apr 06, 2010 7:49 am Post subject: |
So if I buy that deluxe pulldown repair kit on there I should have everything I need to fix it? I just looked at it again, and there's a green ribbon of wire coming off that's cut, but if I plug the thing in it turns on. I'm guessing maybe a bit of wiring, that kit, and all should be good. Thanks man. _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
Posted: Tue Apr 06, 2010 7:51 am Post subject: |
it sounds like your motor is ok, if it turns, you may just need the sliders, and maybe the gear-screw. The deluxe kit includes a new motor.
That is why I suggest digging into it, to try to see if you can figure out what is going on.
The ribbon cable probably got pulled, because it is stuck in the up-possition. So, as soon as you plug it in, it tries to close itself. |
Spikeophant Member
Posted: Tue Apr 06, 2010 8:22 am Post subject: |
Cool, I'll look back there again after work, I'm hoping it stops snowing at some point, it's cold and lame here right now. Fortunately it's not so much snow I can't drive the Camaro.  _________________ 1986 Camaro Z-28 IROC-Z 350 swap |
91camaro_rs Member
Posted: Tue Apr 06, 2010 4:57 pm Post subject: |
i called the guy at top-down solutions he walked me through everything i needed to do to figure out what was wrong with mine, it ended up being the reversing switch, got a new one...works great now! _________________
