GREG DAVIDSON Member
Posted: Wed Mar 10, 2010 11:15 pm Post subject: Brake swap |
Now that i kinda have some money flow back and i noticed my brakes are about shot on my Bird now. I know alot of you have done the swap to the newer style. I either would like a list of parts i need or a web link so i can start gathering parts. Oh yea and its for fronts for now i wanna swap axles for the rear disk later. thanks guys. _________________
Posted: Thu Mar 11, 2010 4:57 pm Post subject: |
A few of us have done the LS1 front brake swap. I have just to buy the pads now. I did the LT1 rear disk's, iansane has done the LS1 rear. No sense in getting a new axle just for the brakes. Easy peasy swap those rears are.
First step in upgrading the front will be to get the bracket design from someone (myself or TGO) and to get a spare set of front rotors that you can turn the rotors off of to make the hubs. _________________ E30
Posted: Fri Mar 12, 2010 6:27 pm Post subject: |
| And bigger wheels, if I'm not mistaken. |
Posted: Fri Mar 12, 2010 6:32 pm Post subject: |
| Yeah, bigger wheels too. They'll clear some 16" wheels, 17" for sure. |
Posted: Fri Mar 12, 2010 6:33 pm Post subject: |
| aaron_sK wrote: | | And bigger wheels, if I'm not mistaken. |
are my 16 inch wheels big enough ? I dont think i need Ian sized brakes on my car yet  |
Posted: Fri Mar 12, 2010 6:39 pm Post subject: |
| GREG DAVIDSON wrote: | | aaron_sK wrote: | | And bigger wheels, if I'm not mistaken. |
I doubt it, I would guess that for C5 brakes, you will need 17". Now, you can use a C5 caliper, with LS1/4thgen rotor and brackets, and that I think should clear a 16" |
Posted: Fri Mar 12, 2010 6:45 pm Post subject: |
Ok i just kinda wanted to maintain my stock sixteens i kinda like them. I suppose i should have said that in the beginning.
So the brackets are pretty avalable then ? I'm about to get another f.a. check soon and i want to start upgrading my brakes and suspension. |
Posted: Fri Mar 12, 2010 6:46 pm Post subject: |
When Ian was selling his C5 fronts I talked to Ed (can't remember his last name) on TGO who does all the brake swap stuff.
He told me that an LS1 rotor and C5 caliper would fit under an IROC wheel, but that for the trouble I would be better just doing an LS1 front swap straight up. |
Posted: Fri Mar 12, 2010 6:48 pm Post subject: |
| Aaron, that suprises me, considering the known issues with LS1 calipers spreading under heavy use. Lots of LS guys swap to the C5 caliper for that very reason. |
Posted: Fri Mar 12, 2010 6:55 pm Post subject: |
| He mentioned the spread issue specifically. However I told him that the car was street and not an auto-x or anything, and that I was looking to get the swap done on the cheap, which I think probably tipped his advice towards the LS1 stuff. |
Posted: Fri Mar 12, 2010 6:59 pm Post subject: |
| Once I get my engine done I want to race it a bit so i prob better go with the C-5 |
Posted: Fri Mar 12, 2010 7:00 pm Post subject: |
| GREG DAVIDSON wrote: | | Once I get my engine done I want to race it a bit so i prob better go with the C-5 |
What kind of racing? Depending on teh kind of racing, different brake upgrades may change your car's classification. |
Posted: Fri Mar 12, 2010 7:04 pm Post subject: |
I love the design and size of the C4 HD but I hate the pin fit retention. It's super easy, but the slightest out of true in the rotor and the bastards squeek! _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 12, 2010 7:11 pm Post subject: |
| Dewey316 wrote: | | GREG DAVIDSON wrote: | | Once I get my engine done I want to race it a bit so i prob better go with the C-5 |
Most likley drag racing but i want to auto-cross someday. Plus im not very easy on my cars so i need all the upgrades possable.  |
Posted: Fri Mar 12, 2010 9:05 pm Post subject: |
Go big or go home damnit! The LS1s will also give you a large piston, for what it's worth... (edit, larger compared to the c5s)
If you've keeping your stock 16s then c4HDs, LS1s, LS1 bracket w/ C5, or even the wilwoods that mike has are about your only options. _________________
Posted: Fri Mar 12, 2010 9:10 pm Post subject: |
| iansane wrote: | Go big or go home damnit! The LS1s will also give you a large piston, for what it's worth...
If you've keeping your stock 16s then c4HDs, LS1s, LS1 bracket w/ C5, or even the wilwoods that mike has are about your only options. |
hehe yeah. The C4HD BARELY fit IROC wheels. I don't know if they'll clear the bird tapered wheel. _________________ A redline a day keeps the carbon away! |
Posted: Fri Mar 12, 2010 9:14 pm Post subject: |
I thought the crosslace wheels are the only ones that are tapered? _________________
Posted: Fri Mar 12, 2010 9:17 pm Post subject: |
| Maybe Dan will post up. But when he was testing his prototype, which i think was C4HD my formy wheels fit great.. But mikes crosslaces failed. |
alloy T56 Elitist
Posted: Fri Mar 12, 2010 10:32 pm Post subject: |
The only thing I tried was my wilwood setup. Did the LS1's on my stock irocs and John's 15" rally wheels only. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
