GREG DAVIDSON Member
Posted: Sat Feb 20, 2010 2:16 pm Post subject: Track bar brace |
where it mounts above the track bar it self is that threaded into the housing i got the nut off but cant get the bolt out must just be rusted in there _________________
Posted: Sat Feb 20, 2010 2:24 pm Post subject: |
It would be rusted in. The single bolt is a slide thru just like the track bar. Now the 3 bolt end, them thread into the body obviously. _________________ 2008 GMC Z71
Posted: Sat Feb 20, 2010 2:35 pm Post subject: |
yea i've got the body bolts out, i was just making shure i wasnt going to screw somthing up thank you now back to beating the crap out of it . its waaaay to nice a day to waste inside so i'll work on it till it ticks me off to much, i want to get it fixed so i can maybe drive it to dyno with the daytona but it shure is fighting me  |
Posted: Sat Feb 20, 2010 3:21 pm Post subject: |
| I had to take a sawzall with a fire/rescue blade to mine. Ran it up between the body and the bar itself. Then replace it with a diff trackbar n bolt. |
Posted: Sat Feb 20, 2010 3:37 pm Post subject: |
| yea it may come to that. im using an air hammer and a bfh and still no budging |
Posted: Sat Feb 20, 2010 10:25 pm Post subject: |
| I've had the same problem getting mine out. Hard to beat it out too! If you got it out you can see the problem is the bolt rusts to the inside metal sleeve of the bushing. Think I used some PB Blaster and a pry bar. Wedged the prybar in between the bracket and the track bar and, well, pried. |
Posted: Sat Feb 20, 2010 11:23 pm Post subject: |
| yea i still havnt gotten it yet its way bad i think im going to try and cut it off tomarrow |
Posted: Sun Feb 21, 2010 1:21 pm Post subject: |
| how much of a load does this carry ? i know its a brace but how much pressure is on it during hard driving ? |
Posted: Sun Feb 21, 2010 3:35 pm Post subject: |
| Not counting peak load, I would imagine it would carry the rear of the vehicles weight. So 1400lbs? Cause if you can do 1G, then that's as much force laterally as is applied down. |
Posted: Sun Feb 21, 2010 5:16 pm Post subject: |
| blue89 wrote: | | Not counting peak load, I would imagine it would carry the rear of the vehicles weight. So 1400lbs? Cause if you can do 1G, then that's as much force laterally as is applied down. |
The track bar itself or the brace above it? _________________
Posted: Sun Feb 21, 2010 5:23 pm Post subject: |
| the brace above it is what i was going for |
