Track bar brace
PostPosted: Sat Feb 20, 2010 2:16 pm    Post subject: Track bar brace Reply with quote
where it mounts above the track bar it self is that threaded into the housing i got the nut off but cant get the bolt out Confused must just be rusted in there
PostPosted: Sat Feb 20, 2010 2:24 pm    Post subject: Reply with quote
It would be rusted in. The single bolt is a slide thru just like the track bar. Now the 3 bolt end, them thread into the body obviously.
PostPosted: Sat Feb 20, 2010 2:35 pm    Post subject: Reply with quote
yea i've got the body bolts out, i was just making shure i wasnt going to screw somthing up thank you now back to beating the crap out of it Laughing . its waaaay to nice a day to waste inside so i'll work on it till it ticks me off to much, i want to get it fixed so i can maybe drive it to dyno with the daytona but it shure is fighting me Sad
PostPosted: Sat Feb 20, 2010 3:21 pm    Post subject: Reply with quote
I had to take a sawzall with a fire/rescue blade to mine. Ran it up between the body and the bar itself. Then replace it with a diff trackbar n bolt.
PostPosted: Sat Feb 20, 2010 3:37 pm    Post subject: Reply with quote
yea it may come to that. im using an air hammer and a bfh and still no budging
PostPosted: Sat Feb 20, 2010 10:25 pm    Post subject: Reply with quote
I've had the same problem getting mine out. Hard to beat it out too! If you got it out you can see the problem is the bolt rusts to the inside metal sleeve of the bushing. Think I used some PB Blaster and a pry bar. Wedged the prybar in between the bracket and the track bar and, well, pried.
PostPosted: Sat Feb 20, 2010 11:23 pm    Post subject: Reply with quote
yea i still havnt gotten it yet its way bad i think im going to try and cut it off tomarrow
PostPosted: Sun Feb 21, 2010 1:21 pm    Post subject: Reply with quote
how much of a load does this carry ? i know its a brace but how much pressure is on it during hard driving ?
PostPosted: Sun Feb 21, 2010 3:35 pm    Post subject: Reply with quote
Not counting peak load, I would imagine it would carry the rear of the vehicles weight. So 1400lbs? Cause if you can do 1G, then that's as much force laterally as is applied down.
PostPosted: Sun Feb 21, 2010 5:16 pm    Post subject: Reply with quote
The track bar itself or the brace above it?
PostPosted: Sun Feb 21, 2010 5:23 pm    Post subject: Reply with quote
the brace above it is what i was going for
