fiveoformula Member
Posted: Tue Jan 26, 2010 11:15 pm Post subject: valve seals |
Replacing the valve stem seals on the bird soon. Are these what I want?
I bought umbrella seals from NAPA the other day, but im wondering if I should get these too.
http://www.summitracing.com/parts/FEL-SS72527/ |
Posted: Tue Jan 26, 2010 11:35 pm Post subject: |
Umbrellas don't do shizzle.
You SHOULD have positive seals. Without pulling a valve cover you wont know for sure.
You'll need 16.
There are several sizes you got the 11/32" right for the valve stem, but the base where it hooks to the head can be .500, .530, .560 and more. _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Wed Jan 27, 2010 12:25 pm Post subject: |
| Ok so I'll take the umbrella's back and see if I can find these locally, sounds like I'll have to compare to the original for sizing still though right? |
Posted: Wed Jan 27, 2010 4:49 pm Post subject: |
Yup...
Need to know what diameter the valve guide is. I can't find any consistant information myself. _________________ A redline a day keeps the carbon away! |
Posted: Wed Jan 27, 2010 5:34 pm Post subject: |
| You should be able to order stockers. I know they just come in a headset if you buy one, so there must be some kind of catalogging somewhere. |
fiveoformula Member
Posted: Wed Jan 27, 2010 10:11 pm Post subject: |
| That part number I posted is the same fel-pro between both summit and jegs. |
Posted: Wed Jan 27, 2010 10:14 pm Post subject: |
| Forgot felpro and gm like to use positive seals on the intakes only. Victor used to have positives for the exhausts as well. Supposedly made out of different material. I usually just use the same ones for both. |
fiveoformula Member
Posted: Wed Jan 27, 2010 10:40 pm Post subject: |
| Is there an advantage to using different ones on the exhaust? lol I don't get why they'd do that. |
Posted: Wed Jan 27, 2010 10:43 pm Post subject: |
| The reasoning is that the exhaust doesnt have vacuum sucking the oil down the guide. Therefore only the o-ring is needed. |
fiveoformula Member
Posted: Wed Jan 27, 2010 10:56 pm Post subject: |
| That makes sense, hopefully this is the cause of the firebird's blues, it's smoked a bit ever since I got it. |
Posted: Wed Jan 27, 2010 11:04 pm Post subject: |
Still need something though. Had a motor with 100 miles on it come in and the teflon seals... two of them were leaking down the stem into the exhaust port! lol _________________ A redline a day keeps the carbon away! |
fiveoformula Member
Posted: Thu Jan 28, 2010 12:19 pm Post subject: |
| Wow, sucks for that guy. Unless he wanted a well oiled exhaust system. lol |
Posted: Fri Jan 29, 2010 6:07 pm Post subject: |
| Quote: | Bulletin Number: 91-6-55
Reference Number: 136007
Publish Date: 11/91
Models 1987-91 FIREBIRD AND GRAND PRIX
Affected: MODELS W/5.0 and 5.7L
This bulletin cancels and supersedes bulletin 88-6-91A issued 3/89 and 88-6-85 issued 12/88. Please discard these two bulletins.
A new valve stem seal kit (P/N 12511890) has been released to address this concern. The kit incorporates a new umbrella seal with a "viton" insert for the exhaust valve stem.
Parts are currently available from GMSPO. |
That's all I have to offer, but I'm sure you already knew this. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
