d00012 Member
Posted: Sun Jan 17, 2010 5:26 pm Post subject: SHE LIVES!!! |
Time for me to tear up the asphalt again! (not really, it's a 2.8 )
I just finished putting all suspension back together today. One scary moment when the jack slid off a board it was on and the car fell off it's supports! Luckily, nothing broke!
I took it out for a little spin, wow, my fuel pump must have been in a failing state looong before it finally died for good. Pulls nicely in the top end!
Time to celebrate with some SAKE!! (real sake from Japan, not imported, bought IN Japan )
Oh, and I won't be doing an access panel in the Firebird. Dropping the tank is just too easy.
alloy T56 Elitist
Posted: Sun Jan 17, 2010 9:37 pm Post subject: |
I hope you reconsider cutting an access door. These are uni-body cars and no matter how you do it you will weaken the body structure. Since your doing one now, the second one will go much faster.
But if you do go ahead, make sure you don't have square corners. Radius them so you won't have a place for cracks to start. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
90droptoproc Member
Posted: Sun Jan 17, 2010 9:40 pm Post subject: |
ya, just don't do it, it really isn't a hard enough job to justify cutting up the car that bad (fire suit on) _________________
Posted: Sun Jan 17, 2010 9:56 pm Post subject: |
| I've never been a fan of the access door. I wouldn't do it on my own car. I have dropped the tank on my car 4-5 times now, it isn't so bad, just pull the tank, |
Posted: Mon Jan 18, 2010 7:11 am Post subject: |
IF I was to do an access panel, it'd be pulling the tank... pulling the carpet and welding in a reinforced sealed door.
I've had mine out twice, and never doored it.
No Hack jobs. _________________ A redline a day keeps the carbon away! |
d00012 Member
Posted: Mon Jan 18, 2010 12:13 pm Post subject: |
alloy T56 Elitist
Posted: Mon Jan 18, 2010 12:37 pm Post subject: |
A few small screws in a plate will not have the same strength as the original sheet metal has. As Paul said if you welded a flange in and sealed it, then maybe. But the amount of work that takes is way more than just pulling the tank and replacing the pump.
It's your car, do as you see fit. All of us here have recommended against it. It's just not that big of a deal to pull the tank. _________________ Member of the "Elite T56 Club" , big brake club, and "burgundy" (not red or maroon) car owner.
d00012 Member
Posted: Mon Jan 18, 2010 12:57 pm Post subject: |
90droptoproc Member
Posted: Tue Jan 19, 2010 7:37 pm Post subject: |
still have to figure a proper way to deal with the high pressure fuel lines, since they are long and wind down the tank in a way that won't let you pull the pick up out of your access door  |
BigDaddyVu 12sec Club
Posted: Wed Jan 20, 2010 9:41 am Post subject: |
I worry about exhaust gas or tire smoke leaking through. _________________
Posted: Wed Jan 20, 2010 10:17 am Post subject: |
| BigDaddyVu wrote: | | tire smoke leaking through. |
d00012 Member
Posted: Wed Jan 20, 2010 11:56 am Post subject: |
Posted: Wed Jan 20, 2010 10:13 pm Post subject: |
Posted: Wed Jan 20, 2010 10:40 pm Post subject: |
| Or how about a bad fire when you get in a car accident? It is the gas tank right there. |
d00012 Member
Posted: Thu Jan 21, 2010 7:09 am Post subject: |
d00012 Member
Posted: Sun Jan 31, 2010 9:21 pm Post subject: |
Another third gen back on the road! Read my first post above!
Posted: Sun Jan 31, 2010 9:28 pm Post subject: |
Posted: Sun Jan 31, 2010 9:37 pm Post subject: |
Cool!!
Just read your post over on TGO What's the 3.4 long block going to be for?? _________________ 92 Camaro
d00012 Member
Posted: Sun Jan 31, 2010 9:43 pm Post subject: |
My camaro. Going to build it up. For a little extra power.
Head work, cam, EBL, headers..stuff like that.
I think it came out of a '95 Camaro. |
