blinkers got no blink
PostPosted: Wed Jan 06, 2010 4:49 pm    Post subject: blinkers got no blink Reply with quote
well i was driving around today and my blinkers stopped blinking they still light up but no blink Confused this happened a few years ago and i just ended up having to clean out the socket but so far that dosnt seam to be working. also the hazzards work fine still. any ideas on what to check next would be great
PostPosted: Wed Jan 06, 2010 5:40 pm    Post subject: Reply with quote
If neither side blinks try replacing the Flasher. I'm actually not sure where it is on a 3d gen, but its either in the fuse box or hanging somewhere near the column usually. Emergencies use a seperate flasher.
PostPosted: Wed Jan 06, 2010 6:02 pm    Post subject: Reply with quote
I'm with stupid
I believe they're located on the "convienence center" Should be right about where your ALDL port is to the right of the column under the dash.
townaj
PostPosted: Thu Jan 07, 2010 3:05 pm    Post subject: Reply with quote
Yup I just had my dash out. Its a ways above the ALDL and right next to the column. Good luck man, idk how to change it without yankin the whole dash. But if the hazards still work isn't it something else?
And your sure its not out of blinker fluid?? Lol just messin with ya man. Ugh thats a horrible joke lol.
PostPosted: Thu Jan 07, 2010 3:23 pm    Post subject: Reply with quote
No, hazards have their own flasher, separate from the blinkers. Identical pieces, if you find both, switch them and see if the problem moves with the bad one. One of mine was attached to a bracket on the column(blinker I believe), the other is up above the convenience center by the ALDL.
townaj
PostPosted: Thu Jan 07, 2010 3:37 pm    Post subject: Reply with quote
Oh ok. Yeah mine was connected to the column also. Thats a good thing to know-i had no idea there was two.
PostPosted: Thu Jan 07, 2010 5:07 pm    Post subject: Reply with quote
ok thanks for the help it was the flasher so im happy it was only a 5$ fix. but know i can tell that the last one was going cause for the time i had the car the turn signal blinked once about ever 2 seconds know they blink once or twice a second
PostPosted: Fri Jan 08, 2010 2:19 am    Post subject: Reply with quote
That reminds me, I should do the same thing, mine blink so slow that I'm worried that people won't know that I'm turning.
