cameron7710 Member
Posted: Wed Jan 06, 2010 4:49 pm Post subject: blinkers got no blink |
well i was driving around today and my blinkers stopped blinking they still light up but no blink this happened a few years ago and i just ended up having to clean out the socket but so far that dosnt seam to be working. also the hazzards work fine still. any ideas on what to check next would be great _________________
Posted: Wed Jan 06, 2010 5:40 pm Post subject: |
| If neither side blinks try replacing the Flasher. I'm actually not sure where it is on a 3d gen, but its either in the fuse box or hanging somewhere near the column usually. Emergencies use a seperate flasher. |
Posted: Wed Jan 06, 2010 6:02 pm Post subject: |
I believe they're located on the "convienence center" Should be right about where your ALDL port is to the right of the column under the dash. _________________
townaj Member
Posted: Thu Jan 07, 2010 3:05 pm Post subject: |
Yup I just had my dash out. Its a ways above the ALDL and right next to the column. Good luck man, idk how to change it without yankin the whole dash. But if the hazards still work isn't it something else?
And your sure its not out of blinker fluid?? Lol just messin with ya man. Ugh thats a horrible joke lol. |
Posted: Thu Jan 07, 2010 3:23 pm Post subject: |
| townaj wrote: | | But if the hazards still work isn't it something else? |
No, hazards have their own flasher, separate from the blinkers. Identical pieces, if you find both, switch them and see if the problem moves with the bad one. One of mine was attached to a bracket on the column(blinker I believe), the other is up above the convenience center by the ALDL. _________________ 92 Camaro
townaj Member
Posted: Thu Jan 07, 2010 3:37 pm Post subject: |
| Oh ok. Yeah mine was connected to the column also. Thats a good thing to know-i had no idea there was two. |
cameron7710 Member
Posted: Thu Jan 07, 2010 5:07 pm Post subject: |
ok thanks for the help it was the flasher so im happy it was only a 5$ fix. but know i can tell that the last one was going cause for the time i had the car the turn signal blinked once about ever 2 seconds know they blink once or twice a second _________________
Posted: Fri Jan 08, 2010 2:19 am Post subject: |
That reminds me, I should do the same thing, mine blink so slow that I'm worried that people won't know that I'm turning. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
