cooling fan question
PostPosted: Sat Nov 21, 2009 1:43 pm    Post subject: cooling fan question Reply with quote
my cooling fan can on lastnight while driving it and it wont shut off now i had to find the plug for it and unplug it to get it to shut off, any idea what i need to fix ? the temp gauge kinda worked when it wanted to so im thinking i may need a new sending unit ? would that cause the fan itself to stay on ?
oh and this is on my Daytona 2.2 btw
PostPosted: Sat Nov 21, 2009 1:57 pm    Post subject: Reply with quote
Sounds like the relay stayed open. Fan gets battery power straight from the relay so if the relay stays on, the fan stays on.
Or the key on power/ecm power to the relay is staying on for some reason.
Sounds like relay
PostPosted: Sat Nov 21, 2009 1:59 pm    Post subject: Reply with quote
ok i'll have to see if i can find it , its been a few years since i've worked on one of these
Outlaw28
PostPosted: Sat Nov 21, 2009 2:14 pm    Post subject: Reply with quote
just go buy an aftermarket one off summit...i think the one i bought was 20bucks works great easy to install comes with all the hardware and its adjustable
Assuming it's a standard four-wire relay, you should be able to quickly test if the trigger has both 12V and ground. If not, it's a bad relay as Paul mentioned. If they do, then think faulty sending unit grounding out, or something along those lines. I'm not sure if Mopar ran switched 12V, or switched ground to trigger the relay.
PostPosted: Sat Nov 21, 2009 4:19 pm    Post subject: Reply with quote
whent out and plugged the fan back in, yep fan kicked on so i found the relays on the fender well, started tapping on them with a wrench one by on and magically the fan shut off Rolling Eyes NAPA is the only one to have it on hand. seems to be there the place to go for relays, switches and sending units here in salem that was the situation for the firebird i had before, the parts houses down here are kinda full of idiots. Rolling Eyes
PostPosted: Sat Nov 21, 2009 4:22 pm    Post subject: Reply with quote
GREG DAVIDSON wrote:
the parts houses everywhere are completely full of idiots. Rolling Eyes
Fixed it for ya. Very Happy
PostPosted: Sat Nov 21, 2009 4:27 pm    Post subject: Reply with quote
Laughing i didnt want to say it that way cause theres a few people that work in parts houses in the crew Laughing but the day that the schmucks here in town basically said coreys mitsubishi was a better and more powerfull car than my bird ... they lostmy buisness all together... frikin idiots Evil or Very Mad
PostPosted: Sat Nov 21, 2009 4:30 pm    Post subject: Reply with quote
His car in particular, no. Razz
A good DSM should be able to handle the average 305 car pretty easily though.
PostPosted: Sat Nov 21, 2009 4:34 pm    Post subject: Reply with quote
not going to deny that.. i still kinda want a 1995-1999 tsi,gsx or even a gst , but im happy with the 4 cylinder i have its a nice slate to work with i hope once i get my bird done the daytona will be pushing some nice hp
PostPosted: Sat Nov 21, 2009 11:38 pm    Post subject: Reply with quote
Squint
91camaro_rs
PostPosted: Sat Nov 21, 2009 11:50 pm    Post subject: Reply with quote
after i did my timing chain my fan wouldnt go off either, funny thing is that once i replaced the CTS sensor, it turned off, idk if those two things are related at all but it worked
PostPosted: Sat Nov 21, 2009 11:55 pm    Post subject: Reply with quote
i'll get both when i get the cash to change them. i drove a bit today the fan seems to be turning on and off on its own hoping its good till weds.
oh and on a side note for the guys that go junk yard surfing could you please keep an eye out for a drivers side fender for me please. i cant find one down here sombody kicked it in just before i bought the car
PostPosted: Sun Nov 22, 2009 1:11 am    Post subject: Reply with quote
Nailed it. Had his relay been good, the CTS or a short in the trigger line would be the next two culprits.
Squint
Hey, since when is BT a parts house. They're barely even a Chebbie dealer. Laughing Razz
PostPosted: Sun Nov 22, 2009 11:48 am    Post subject: Reply with quote
If the cts shorts to ground the fan will only come on when they key is on.
91camaro_rs
PostPosted: Sun Nov 22, 2009 12:29 pm    Post subject: Reply with quote
or if you cant plug it in cause the plug on it snapped like mine Laughing
PostPosted: Sun Nov 22, 2009 1:01 pm    Post subject: Reply with quote
Greg was talking about his dodge. The ECM controls the cooling fan. An open in the CTS circuit or disconnecting the CTS will turn the cooling fan on. That shouldnt happen with the key off though. So if the fan continued to run after the key is off then its most likely the relay sticking.
PostPosted: Sun Nov 22, 2009 2:56 pm    Post subject: Reply with quote
Oh. Embarassed
PostPosted: Sun Nov 22, 2009 4:53 pm    Post subject: Reply with quote
Heheh.. remember how you time one? You disconnect the cts.. and then the computer goes into limp mode, fan comes on, and you can set the timing. The fan coming on is what the texts tell you to listen for before trying to time it.
PostPosted: Sun Nov 22, 2009 5:37 pm    Post subject: Reply with quote
Don't recall having timed one. And missed the Dodge bit in the first post. Razz Rolling Eyes
