Round 2 didnt take, not even running yet
PostPosted: Tue Nov 10, 2009 5:10 pm    Post subject: Round 2 didnt take, not even running yet Reply with quote
Well, round 2 on the head gaskets didnt take. Its not even running yet, not even fully bolted together, and its leaking coolent.... both sides
So my guess is, these 1003 gaskets suck ass, or these heads are worped(sp?)
Studs used, 80psi
no copper coat
Found out about a new machine shop since this last one cant seem to keep date promises. Going to take them in and see if they are ok, and what HE would recommend using for gaskets.
SOOOOOOOOOOOOOOOOOOO pissed. Ive waisted almost 400 bux in just gaskets now.
PostPosted: Fri Nov 13, 2009 10:15 am    Post subject: Reply with quote
Well, found out round 2 problem was an installers error. Doh!
Partly fixed last night w/o buying new gaskets. Filled with fluid to check for leaks when I get home. :fingerscrossed:
PostPosted: Fri Nov 13, 2009 10:25 am    Post subject: Reply with quote
What did you do? Just thought it might be helpful for others potentially.
Good luck. Hope this gets it.
PostPosted: Fri Nov 13, 2009 10:30 am    Post subject: Reply with quote
I got distracted by a phone call, and large chested woman jogging....didnt tighten all the bolts Embarassed
Had to remove the alt, ps, drivers header.
Plus to install the studs in the ends, I had to remove 4 rockers, compress the spring, and pry it outta the way.
Not 100% this fixed it, but we shall see.
PostPosted: Fri Nov 13, 2009 10:33 am    Post subject: Reply with quote
Your excuse is officially accepted.
Laughing so hard it hurts
Hey, at least 50% of your excuse has merit Wink
edit: Ninja'd!
PostPosted: Sat Nov 14, 2009 9:00 pm    Post subject: Reply with quote
Jeez man. Check, check, and recheck! Now keep your garage closed and do work son!
PostPosted: Sat Nov 14, 2009 9:26 pm    Post subject: Reply with quote
That happens, I always budget more time for a project when Jenn helps me. Razz
PostPosted: Sat Nov 14, 2009 10:03 pm    Post subject: Reply with quote
Your a brave man to say that in public Wink
Jenn
1987 Pontiac Firebird
PostPosted: Sun Nov 15, 2009 8:38 am    Post subject: Reply with quote
You're fun to distract tho. The sound of wrenches hitting the floor makes me grin Twisted Evil
