TurdGen1989 Member
Posted: Thu Nov 12, 2009 4:47 pm Post subject: Problem |
ok well this morning i went out to start my car and it turned over for a while and did start. I tried again and it wont even turn over ... even right now i have it hooked up to the battery charger i turn the key on and the volts are right at 13 on the gauge and still nothing:????
any suggestions?
oh and my starter/ solenoid is only like 2 months old _________________ Phil.
GMC High Sierra
kurfbird Member
Posted: Thu Nov 12, 2009 5:53 pm Post subject: Gauges on cluster are incurate. |
Gauges pmc;uster are incurate. 13 volts but how many Amps. You need to let it charge for a while thent ry and start it _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
TurdGen1989 Member
Posted: Thu Nov 12, 2009 5:54 pm Post subject: |
i let it sit on it for like 20 minutes and still nothing? _________________ Phil.
GMC High Sierra
izcain 9sec Club
Posted: Thu Nov 12, 2009 6:14 pm Post subject: |
Nothing meaning it turns over but no fire or meaning that it just clicks without anything else? _________________
9.17 @ 148 |
Wait, so it turned over and started, and now it wont crank at all, and you somehow suspect the battery died?
I'd be looking at bad connections at the batt hot and starter, VATS, bad P/N switch (or in gear ). Takes a lot to kill a battery. |
TurdGen1989 Member
Posted: Thu Nov 12, 2009 7:37 pm Post subject: |
yea it did it this morning it turned over fine but now nothing ... i left the charger on it for like 20 minutes and then tried jumping it.. there is no security light its in park.. idk what the hell is going on?
AHHHHHHHHH!!! /rant  _________________ Phil.
GMC High Sierra
kurfbird Member
Posted: Thu Nov 12, 2009 7:43 pm Post subject: Battery Charger |
Battery charges take alone time charge a battery. Hours. _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
townaj Member
Posted: Thu Nov 12, 2009 7:44 pm Post subject: |
| What about fuses? Could those do it if ones blown? |
Posted: Thu Nov 12, 2009 7:52 pm Post subject: |
Fuses shouldn't cause a no-crank issue.
If the battery has enough juice to give you lights and gauges, then it would have enough juice to at least give you a weak crank, or a solenoid click. Also, it verifies 12V from the batt to the main starter lug.
Check if the trigger (fat purple) wire to the solenoid is hot when cranking. |
TurdGen1989 Member
Posted: Thu Nov 12, 2009 8:00 pm Post subject: |
yea it had plenty of juice .. but nothing and this has never been a problem b4
GMC High Sierra
Posted: Thu Nov 12, 2009 8:11 pm Post subject: |
| You need to check that the line to the solenoid has power. If that line "has juice" as you say, then the solenoid is shot. |
popballz Member
Posted: Thu Nov 12, 2009 10:13 pm Post subject: |
I just fixed a problem like that....
mine was the wire to the starter had 12v but it was so corroded on the inside it didn't even turn the starter over..so you should check that _________________ -Donald
Posted: Thu Nov 12, 2009 10:18 pm Post subject: |
| popballz wrote: | I just fixed a problem like that....
mine was the wire to the starter had 12v but it was so corroded on the inside it didn't even turn the starter over..so you should check that |
So that was what caused the Ford problem?  |
Red Bird Member
1991 Pontiac Firebird
Posted: Fri Nov 13, 2009 8:41 am Post subject: |
It might be a vats problem. i had a problem a similar issuewith my 1991 firebird. somtimes my car would turn over fine and somtimes not at all. i replaced the starter, battery,and battery cables ignition stitch and it turned out to be a vats issue. does ur key have a chip? I had to wire in a resistor that matched the chip in the key's resistance to disable vats and to get it to fire everytime. thats the cheap way of getting around it, u can program it out with chip tuning also,or replace it with new stuff to keep it working. no problems with it ever since. just another possibility. _________________ 1991 Firebird L03 T-5 |
Posted: Fri Nov 13, 2009 10:10 am Post subject: |
He says no vats light. But that light could be blown. But yea, if vats was triggered, it is "dead", no click, nothing. It also takes IIRC 5min from the last try for it to reset itself. When I had issues with mine, I could breath on the chip/key for a few seconds, and make it work???
I had a problem with a corroded wire once. It would give me lights, but lights would dim when you turn the key.
You say the starter is "new". Re-check your connections. Maybe you didnt get something tight. (been there, done that) |
TurdGen1989 Member
Posted: Fri Nov 13, 2009 2:00 pm Post subject: |
| 91RSVert wrote: | He says no vats light. But that light could be blown. But yea, if vats was triggered, it is "dead", no click, nothing. It also takes IIRC 5min from the last try for it to reset itself. When I had issues with mine, I could breath on the chip/key for a few seconds, and make it work???
ill do that... also i have a spare key so maybe ill see if the chip is better on that one or something?
edit: nvm definitely not vats just tried it ... so i guess ill try the starter tomorrow if it doesn't rain cuz i didnt get to get my car under the garage  _________________ Phil.
GMC High Sierra
