TurdGen1989 Member
Posted: Tue Oct 13, 2009 8:15 pm Post subject: couple parts wanted |
well im looking for a magnaflow muffler and some gears preferably 3:73s or something like that thanks guys
phil _________________ Phil.
GMC High Sierra
Posted: Tue Oct 13, 2009 8:57 pm Post subject: |
| You want the Muffler, or the entire catback? |
TurdGen1989 Member
Posted: Tue Oct 13, 2009 9:23 pm Post subject: |
just the muffler i have a catless exhaust right now just want a little better sound ... im cutting my piping down a little so im looking for like a chambered muffler or even flowmaster dont matter to me
like this one not the stock one lol _________________ Phil.
GMC High Sierra
Posted: Tue Oct 13, 2009 9:39 pm Post subject: |
Got an entire Magnaflow catback sitting in the back of my Dad's shop. Needs to go as a set, though.
Bear in mind when you buy a muffler for a third-gen, that the stock setup has a cross-flow one in/two out setup. If you buy a single in/out you'll need to rework the bend over the axle, and run a single tip. |
TurdGen1989 Member
Posted: Tue Oct 13, 2009 9:53 pm Post subject: |
yea im just gonna run a single muffler on the passenger side... since its straight there.. i did some measuring and it will work ...
maybe something like this would work better too...
http://www.magnaflow.com/02product/02race.asp
or
http://www.spintechmufflers.com/spintech/spintechindex.asp
since their flatter idk lol
im going to shorten my piping alot prolly because its not hooked up right anyway ... just til i get an actual exhaust system _________________ Phil.
GMC High Sierra
GREG DAVIDSON Member
Posted: Tue Oct 13, 2009 10:56 pm Post subject: |
| hey aaron what do you want out of the catback if he's not interested ? i blew a hole in the bend of mine and i dont have a welder yet |
Posted: Wed Oct 14, 2009 12:12 am Post subject: |
| Greg, I think I paid around $300 for it a few years ago. It's like $450 new from Summit. Would want about $250 obo for it. It's a really nice fully-stainless mandrel system. Has tips, cat flange, and all the clamps as well. |
jakemk8706 Member
Posted: Wed Oct 14, 2009 7:54 am Post subject: |
i have some stock 3.42 gears if your interested _________________ gas brake dip dip |
TurdGen1989 Member
Posted: Wed Oct 14, 2009 3:14 pm Post subject: |
| jakemk8706 wrote: | | i have some stock 3.42 gears if your interested |
they'll fit in a stock rs rear end wont it? _________________ Phil.
GMC High Sierra
TurdGen1989 Member
Posted: Thu Oct 15, 2009 3:35 pm Post subject: |
hah i guess not _________________ Phil.
GMC High Sierra
kurfbird Member
Posted: Thu Oct 15, 2009 4:26 pm Post subject: gears |
I have a rear end from a 91 rs with 3.42 non posi. 60.00
Cant meet becasue my truck trans is still out _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Fri Oct 16, 2009 9:17 am Post subject: |
| TurdGen1989 wrote: | | jakemk8706 wrote: | | i have some stock 3.42 gears if your interested |
they'll fit in a stock rs rear end wont it? |
They might, but there's a couple variables here.
1) They have to be a ring/pinion that fit GM 7.5 or 7.625 10 bolt carriers. (he said "stock", so I'm guessing so here..)
2) if #1 is true, you need to find out if you have at least 3.23 or numerically higher gears, if not...you have what is called a "2 series carrier" (thing that the ring gear bolts to) which means you will need a ring gear spacer like this one:
http://stores.channeladvisor.com/Summit-Racing-Equipment/Items/MGR-075050
Also, you'll need a dial indicator to set pinion depth, a set of carrier and pinion gear shims, and probably someone who's done it before with ya to help or walk you through it.
all that being said.......
you're probably best off to find someone with a whole 3.42 or 3.73 axle that is complete.
my humble $.02 _________________
TurdGen1989 Member
Posted: Fri Oct 16, 2009 3:19 pm Post subject: |
yea i guess that sounds easier i might just try and buy one because i got got what? 2.70s? lol i just want some better gears to make my 700r more fun! _________________ Phil.
GMC High Sierra
Posted: Fri Oct 16, 2009 3:51 pm Post subject: |
| Have you checked RPO's or the axle tag to confirm the ratio? |
TurdGen1989 Member
Posted: Sat Oct 17, 2009 10:20 am Post subject: |
idk where to find the RPO codes?
and the tag says nothing... but i know i can do 60 in second at like 3800rpm.. _________________ Phil.
GMC High Sierra
Posted: Sat Oct 17, 2009 10:28 am Post subject: |
| RPO codes are in the glovebox, or in the rear hatch storage box. From your description it does sound like a 2.7x-ish ratio though. |
