Lose 5 lbs in one day
85 T/A WS6
1985 Pontiac Trans Am
PostPosted: Tue Jun 16, 2009 6:09 pm    Post subject: Lose 5 lbs in one day Reply with quote
PostPosted: Wed Jun 17, 2009 6:55 am    Post subject: Reply with quote
Lol, same inside diameter?
85 T/A WS6
PostPosted: Wed Jun 17, 2009 7:21 am    Post subject: Reply with quote
Yes, its 3-1/2" wide, Catco direct fit, hi flow.
The old cat was broke about 1/8 the way on the exit end, so the element didnt align. Runs better now Smile, slight improvement on the exhaust note too.
Im getting too old for this!
See you at Meeker Days Smile
91camaro_rs
PostPosted: Wed Jun 17, 2009 9:16 am    Post subject: Reply with quote
im thinkin about replacing my cat with a hi flow, i gutted mine and i think i lost some power by doing that Laughing but it sure does sound good with it gutted
PostPosted: Wed Jun 17, 2009 12:11 pm    Post subject: Reply with quote
I supposibly have a "hi flow" that can be bolted in mine. I notice a MAJOR power drop when I bolt it in.
PostPosted: Wed Jun 17, 2009 1:05 pm    Post subject: Reply with quote
What did you have in there before? You shouldn't really notice anything. A good cat of proper sizing should only snag 5-7hp and that's not going to be anything but barely noticable if at all in the butt dyno.
dlp
1990 Chevrolet Camaro IROC-Z
PostPosted: Wed Jun 17, 2009 8:36 pm    Post subject: Reply with quote
Long story short, I have a brand new no name direct fit high flow CAT and just recieved a used SLP exhaust system from a guy in Texas that included a Catco CAT. The Catco CAT is alot lighter. But.....I cant see through it. Wounder if they actualy work? If not there is no reason to installl it.
PostPosted: Thu Jun 18, 2009 2:39 am    Post subject: Reply with quote
I'm comparing to an "off road test pipe" Wink
PostPosted: Fri Jun 19, 2009 8:45 pm    Post subject: Reply with quote
i made mine lighter by taking a section of galvenized pipe and a 10 lbs hammer and shake out the bits. and it didn't cost anything.
91camaro_rs
PostPosted: Fri Jun 19, 2009 9:18 pm    Post subject: Reply with quote
i did the same thing Laughing
