85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Tue Jun 16, 2009 6:09 pm Post subject: Lose 5 lbs in one day |
85 T/A WS6 Member
Posted: Wed Jun 17, 2009 7:21 am Post subject: |
Yes, its 3-1/2" wide, Catco direct fit, hi flow.
The old cat was broke about 1/8 the way on the exit end, so the element didnt align. Runs better now , slight improvement on the exhaust note too.
Im getting too old for this!
See you at Meeker Days  |
91camaro_rs Member
Posted: Wed Jun 17, 2009 9:16 am Post subject: |
im thinkin about replacing my cat with a hi flow, i gutted mine and i think i lost some power by doing that but it sure does sound good with it gutted |
Posted: Wed Jun 17, 2009 12:11 pm Post subject: |
| I supposibly have a "hi flow" that can be bolted in mine. I notice a MAJOR power drop when I bolt it in. |
Posted: Wed Jun 17, 2009 1:05 pm Post subject: |
| 91RSVert wrote: | | I supposibly have a "hi flow" that can be bolted in mine. I notice a MAJOR power drop when I bolt it in. |
What did you have in there before? You shouldn't really notice anything. A good cat of proper sizing should only snag 5-7hp and that's not going to be anything but barely noticable if at all in the butt dyno. _________________ A redline a day keeps the carbon away! |
dlp Member
1990 Chevrolet Camaro IROC-Z
Posted: Wed Jun 17, 2009 8:36 pm Post subject: |
| Long story short, I have a brand new no name direct fit high flow CAT and just recieved a used SLP exhaust system from a guy in Texas that included a Catco CAT. The Catco CAT is alot lighter. But.....I cant see through it. Wounder if they actualy work? If not there is no reason to installl it. |
Posted: Thu Jun 18, 2009 2:39 am Post subject: |
| Twilightoptics wrote: | | What did you have in there before? You shouldn't really notice anything. A good cat of proper sizing should only snag 5-7hp and that's not going to be anything but barely noticable if at all in the butt dyno. |
I'm comparing to an "off road test pipe"  |
BigDaddyVu 12sec Club
Posted: Fri Jun 19, 2009 8:45 pm Post subject: |
i made mine lighter by taking a section of galvenized pipe and a 10 lbs hammer and shake out the bits. and it didn't cost anything. _________________
91camaro_rs Member
Posted: Fri Jun 19, 2009 9:18 pm Post subject: |
| BigDaddyVu wrote: | | i made mine lighter by taking a section of galvenized pipe and a 10 lbs hammer and shake out the bits. and it didn't cost anything. |
i did the same thing  |
