Jason_Culbertson Member
1982 Pontiac Trans Am
Posted: Wed Mar 25, 2009 3:20 pm Post subject: The smoke is back... |
ok so awhile back i fixed the smoke problem on the T/A but now it's back , Dad says it has something to do with the carb? is that true? and what can i do to fix it? _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3 |
Posted: Wed Mar 25, 2009 3:49 pm Post subject: |
| what kind of smoke problem? |
Posted: Wed Mar 25, 2009 3:51 pm Post subject: |
exhuast smoke for about 5 min (at start up) then stops _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
GREG DAVIDSON Member
Posted: Wed Mar 25, 2009 4:17 pm Post subject: |
| valve seals if im not mistaken... not to much to worry about in my opinion |
Posted: Wed Mar 25, 2009 4:18 pm Post subject: |
What kind of smoke is it? Black smoke, blue(ish) smoke, white smoke?
Valve seals are a quick smoke, right at start up. |
Posted: Wed Mar 25, 2009 7:29 pm Post subject: |
| Dewey316 wrote: | What kind of smoke is it? Black smoke, blue(ish) smoke, white smoke?
white for about 5min then its fine _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
fiveoformula Member
Posted: Wed Mar 25, 2009 7:37 pm Post subject: |
White smoke is usually water/coolant burning or possibly condensation.
Check your oil, make sure theres no coolant in it. _________________
'88 FORMULA |
Posted: Thu Mar 26, 2009 6:36 am Post subject: |
Most cars in this colder weather will have a little white smoke for a few minutes on a cold start because of condensation in the exhaust. The heat from combustion just vaporizes the water on the inside of the pipes.
Even worse if you have a free flowing exhaust and a carbureted car.
Check your oil cap and dipstick for white foam anyway, but I'd say this is totally normal. If you see some whitish foamy stuff, that means coolant is getting into parts of the engine it shouldn't be.
Here's an example of some foam:
Posted: Thu Mar 26, 2009 6:38 am Post subject: |
Should see my RX7 when I start it up in the cold. LOTS of white. _________________ A redline a day keeps the carbon away! |
Posted: Thu Mar 26, 2009 9:24 am Post subject: |
| Jason_Culbertson wrote: | | Dewey316 wrote: | What kind of smoke is it? Black smoke, blue(ish) smoke, white smoke?
white for about 5min then its fine |
If you're worried about white smoke, throw a compression tester on it. Doesn't sound like anything abnormal though. Every car smokes white a little on startup. |
Posted: Thu Mar 26, 2009 9:19 pm Post subject: |
i looked on the cap and dip. and no foam. i forgot to mention that the car has a LOT of water that comes out the exhaust too _________________ ****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
Posted: Thu Mar 26, 2009 9:29 pm Post subject: |
It is that time of year. Cold weather + high humidity = some smokey exaust. My car is pretty bad about it too.
I would start it up on a nice warm dry afternoon, and see if it doesn't smoke. |
Posted: Fri Mar 27, 2009 6:45 am Post subject: |
I have noticed that thick wall exhaust takes much longer to warm up. My LT1 car would send a big trail of fog everywhere I went due to this. The V6 never really did.
If your car isn't sucking down coolant I wouldn't worry about it. |
