The smoke is back...
Jason_Culbertson
1982 Pontiac Trans Am
PostPosted: Wed Mar 25, 2009 3:20 pm    Post subject: The smoke is back... Reply with quote
ok so awhile back i fixed the smoke problem on the T/A but now it's back Crying or Very sad , Dad says it has something to do with the carb? is that true? and what can i do to fix it?
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
"Smoke tires not drugs"
VW and Audi tuner on Forza 3
View user's profile Send private message Visit poster's website MSN Messenger
PostPosted: Wed Mar 25, 2009 3:49 pm    Post subject: Reply with quote
what kind of smoke problem?
Jason_Culbertson
PostPosted: Wed Mar 25, 2009 3:51 pm    Post subject: Reply with quote
exhuast smoke for about 5 min (at start up) then stops
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Wed Mar 25, 2009 4:17 pm    Post subject: Reply with quote
valve seals if im not mistaken... not to much to worry about in my opinion
PostPosted: Wed Mar 25, 2009 4:18 pm    Post subject: Reply with quote
What kind of smoke is it? Black smoke, blue(ish) smoke, white smoke?
Valve seals are a quick smoke, right at start up.
Jason_Culbertson
PostPosted: Wed Mar 25, 2009 7:29 pm    Post subject: Reply with quote
white for about 5min then its fine
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Wed Mar 25, 2009 7:37 pm    Post subject: Reply with quote
White smoke is usually water/coolant burning or possibly condensation.
Check your oil, make sure theres no coolant in it.
'88 FORMULA
PostPosted: Thu Mar 26, 2009 6:36 am    Post subject: Reply with quote
Most cars in this colder weather will have a little white smoke for a few minutes on a cold start because of condensation in the exhaust. The heat from combustion just vaporizes the water on the inside of the pipes.
Even worse if you have a free flowing exhaust and a carbureted car.
Check your oil cap and dipstick for white foam anyway, but I'd say this is totally normal. If you see some whitish foamy stuff, that means coolant is getting into parts of the engine it shouldn't be.
Here's an example of some foam:
PostPosted: Thu Mar 26, 2009 6:38 am    Post subject: Reply with quote
Should see my RX7 when I start it up in the cold. LOTS of white.
PostPosted: Thu Mar 26, 2009 9:24 am    Post subject: Reply with quote
If you're worried about white smoke, throw a compression tester on it. Doesn't sound like anything abnormal though. Every car smokes white a little on startup.
Jason_Culbertson
PostPosted: Thu Mar 26, 2009 9:19 pm    Post subject: Reply with quote
i looked on the cap and dip. and no foam. i forgot to mention that the car has a LOT of water that comes out the exhaust too
****______****
___/,__;i__ \
[___ _ ____;.ŻŻŻl
\_(O)______(O)_/
PostPosted: Thu Mar 26, 2009 9:29 pm    Post subject: Reply with quote
It is that time of year. Cold weather + high humidity = some smokey exaust. My car is pretty bad about it too.
I would start it up on a nice warm dry afternoon, and see if it doesn't smoke.
PostPosted: Fri Mar 27, 2009 6:45 am    Post subject: Reply with quote
I have noticed that thick wall exhaust takes much longer to warm up. My LT1 car would send a big trail of fog everywhere I went due to this. The V6 never really did.
If your car isn't sucking down coolant I wouldn't worry about it.
