townaj Member
Posted: Thu Jan 15, 2009 8:24 pm Post subject: Computer Delete |
| Ok so I don't like having a computer controlling my car. Im weird like that. What do I need to replace so that I can just take the damn thing out? I already did the carb and distributor. Anything else? Because my car is having troubles and I want to be sure that the computer isn't screwing with things before I go replacing random parts. |
Posted: Thu Jan 15, 2009 9:17 pm Post subject: |
If you already ditched the computer contolled carb and distributor then your computer isn't doing anything anymore.
If it's having troubles it isn't the computer. |
Posted: Thu Jan 15, 2009 9:41 pm Post subject: |
| rjmcgee wrote: | If you already ditched the computer contolled carb and distributor then your computer isn't doing anything anymore.
If you just want the wires and whatnot out of the engine bay, the harness to it should be stand-alone. wires go through the passenger side, you may have to loosen or remove the inner fender/splashguard to get the bundle of wires through there., then just trace everything into the engine bay and unplug. _________________
kenf729 Member
Joined: 22 Mar 2007 Posts: 88 Location: Forest Grove, Oregon
Posted: Fri Jan 16, 2009 9:25 am Post subject: |
As I recall the heater and wipers have a gound that hooks into the ground loop that goes through the computer...so I had to re-ground mine... _________________
Posted: Fri Jan 16, 2009 10:07 am Post subject: |
Depending on what year your car is, it may also control your speedo and cruise control. _________________ 2008 GMC Z71
townaj Member
Posted: Fri Jan 16, 2009 5:54 pm Post subject: |
| Ok I figured it wasn't doing much any more but I just wanted to be sure. My car is a 85. The emissions stuff is all vacuum controlled right? |
