Posted: Sun Oct 12, 2008 5:23 pm Post subject: One shiny spot in the engine bay... |
Does this mean I have to get other bright shiny accessories? Or should I get a can of black spray paint and make it look like the rest of the motor? I put on an open element air cleaner and the only way they come apparently is in chrome. I got a drop hat cleaner, but still had to use a 3/4" spacer to clear the throttle linkage. The breather was different to me as it connects to the base and uses the air cleaner element for its filter and it posed the most difficulty (though not hard) to connect. A heater hose elbow stuffed into the valve cover grommet for the breather and a length of 5/8" heater hose to complete the connection did the trick.
 _________________ 92 Camaro
GREG DAVIDSON Member
Posted: Sun Oct 12, 2008 5:28 pm Post subject: |
my vote is to rattle can it , then again i'm not a fan of chrome the open element on mine is black prob just all depends on brand |
cameron7710 Member
Posted: Sun Oct 12, 2008 5:39 pm Post subject: |
there r a few black air cleaners out there but easyer to get chrome. i vote more chrome but painting it would be a lot cheaper and would still look dam good _________________
Posted: Sun Oct 12, 2008 6:20 pm Post subject: |
Throw a K&N in there and it wont seem that bright.
No Paint. |
Posted: Sun Oct 12, 2008 6:32 pm Post subject: |
Just start taking stuff off... and then add some paint. _________________
Posted: Sun Oct 12, 2008 6:40 pm Post subject: |
| John.... your coolant bottle is pretty dirty..... You should paint it... Paint it aluminum! |
Posted: Sun Oct 12, 2008 6:43 pm Post subject: |
| Twilightoptics wrote: | | Paint it aluminum! |
If you will weld it, and tell me what to buy, I will do it. |
Posted: Sun Oct 12, 2008 6:54 pm Post subject: |
fiveoformula Member
Posted: Sun Oct 12, 2008 8:16 pm Post subject: |
Thats the same one I got, along with the K&N, you can see what it looks like in my garage page.
BTW John, did you loose your serpentine set-up? _________________
'88 FORMULA |
Posted: Sun Oct 12, 2008 8:18 pm Post subject: |
One of the brakets broke...and I had it welded, and it broke again. So I replaced it with the V-belt setup. It will work better for me. When I at some poitn put the 2 Eaton superchargers on, I will need the extra room.
--John |
fiveoformula Member
Posted: Sun Oct 12, 2008 8:20 pm Post subject: |
Very nice, Im sure you've researched it more than me, but what do you think of the Weiand TBI supercharger? _________________
'88 FORMULA |
Posted: Sun Oct 12, 2008 8:22 pm Post subject: |
I didn't know weiand made one. I know they make the 142's. And whipple makes a TBI one for the trucks.
Its a lot of money for something, but coule be a pretty neat setup. The hard part is getting a hood that it all fits under. Even a 3" cowl, you would struggle to fit it all under.
Posted: Sun Oct 12, 2008 8:27 pm Post subject: |
| Dewey316 wrote: |  |
Only took about 3 posts with a slight detour back to topic along the way  |
fiveoformula Member
Posted: Sun Oct 12, 2008 8:30 pm Post subject: |
Yeah It would be sweet. I came across the weiand one in a book in the autoparts store, whole kit with belts and a burnt chip, I think it was meant for a 1/2 pickup aswell... Can never find anything "bolt on" for a TBI third gen....
(sorry about the Hijacking!)  _________________
'88 FORMULA |
Posted: Sun Oct 12, 2008 8:36 pm Post subject: |
There isn't really a bolt on supercharger for the cars. And they use a different computer than the trucks do, so even the chip won't help you. For $$$ if you want to go the roots blower route. The standard long-nose 142 with a carb/tbi adatpor plate would work. Then it is jsut a matter of getting a boost refrenced FPR, and doing teh computer work. And on a firebird, probably a 4" cowl to fit it all under.
--John |
fiveoformula Member
Posted: Sun Oct 12, 2008 8:50 pm Post subject: |
You know of anyone who's done it? _________________
'88 FORMULA |
Posted: Sun Oct 12, 2008 8:53 pm Post subject: |
| The closest I have seen, is a guy on TGO who did it many years ago, but he used a 4bbl TBI unit from Holley, and a Commander 950 computer. I'll do a search for the thread on TGO for you, and see if I Can find it. |
fiveoformula Member
Posted: Sun Oct 12, 2008 9:14 pm Post subject: |
Too crazy.
Gotta love anything with a big ol' blower, I don't have a supercharger, and I don't get that kinda mileage!! _________________
'88 FORMULA |
Richster Magic Fingers
Posted: Sun Oct 12, 2008 9:35 pm Post subject: KEEP THE CHROME! |
The chrome looks clean, and so does the master brake cylinder and fluid holder..kind of goes together! _________________
