A bit of carnage
PostPosted: Sat May 10, 2008 3:52 pm    Post subject: A bit of carnage Reply with quote
Truck broke down yesterday. .was just slowly acclerating from behind a school bus.. 1200rpm. When this happens.
I guess a comp XE 262 is fine with the comp roller tips.. But the Voodoo 262 be too much lol. Those parts are off of 2 different valves. The exhaust stud broke, and the pieces got in the way of the intake which bent the pushrod. Luckily no bent valves, or at least the cylinder still holds air fine. Now to figure out how I want to fix this.
PostPosted: Sat May 10, 2008 3:59 pm    Post subject: Reply with quote
Shocked
wow. carnage indeed
PostPosted: Sat May 10, 2008 4:30 pm    Post subject: Reply with quote
Damn! Shocked
Time for some Vortecs
PostPosted: Sat May 10, 2008 4:31 pm    Post subject: Reply with quote
Shocked
Good thing it wasn't worse!
I'm sure you have some, but I have 16 pushrods I pulled out of the 'ole smokey 350 if you need em.
PostPosted: Sat May 10, 2008 4:34 pm    Post subject: Reply with quote
There are piles of pushrods around somewhere.. Trying to decide if i just replace the stud and put it back together.. or get some full rollers.
PostPosted: Sat May 10, 2008 4:36 pm    Post subject: Reply with quote
Wow.
What's Club Pogo? Laughing
PostPosted: Sat May 10, 2008 4:40 pm    Post subject: Reply with quote
Online gaming/chat stuff.
PostPosted: Sat May 10, 2008 4:57 pm    Post subject: Reply with quote
Yikes.
PostPosted: Sat May 10, 2008 5:03 pm    Post subject: Reply with quote
Ouch Shocked
88GTAJim
PostPosted: Sat May 10, 2008 9:17 pm    Post subject: Reply with quote
I think that pushrod is saveable. Just smack it with a hammer a couple of times. Very Happy
88 GTA LB9 5 speed 3.45 posi
Raiden
PostPosted: Sun May 11, 2008 8:14 am    Post subject: Reply with quote
WOW Twisted Evil
PostPosted: Sun May 11, 2008 10:03 am    Post subject: Reply with quote
I swear by the full rollers. Especially after the trouble I had with those stupid pivot ball style.
PostPosted: Sun May 11, 2008 10:09 am    Post subject: Reply with quote
I'm with stupid
No more roller tips for me.
I put mine in the red TPI car this winter after taking them out of the blue car. When I rebuild the 305 I'm gonna take them out of there too.
PostPosted: Sun May 11, 2008 10:47 am    Post subject: Reply with quote
Looks like i'm at the limit on these pivot ball rockers all right. Looking at the springs i'm using.. i'm about 350#s open pressure. This cam is also opening 0.530 with the 1.6 rockers. With the comp cam my lift was only 0.500 and i was using z28 springs.
PostPosted: Sun May 11, 2008 11:11 am    Post subject: Reply with quote
Wow. That's more open pressure than I'm running.
PostPosted: Sun May 11, 2008 1:17 pm    Post subject: Reply with quote
Looks like the springs spec at 330#s at 0.500 lift. So i'm guestimating at 350 at 0.530.. too much anyway lol. The springs are 462# per inch rate. I like how on the jegs site they say upgraded rockers recommended for that cam. I just went ahead and ordered up a set of these..
All USA made, and specs look pretty good. Almost went with CNC's stainless .. which were cheaper. But no idea where they're actually made. Now I'm prayin that when that pushrod got bent it didnt hurt my cam. Another flat cam is all i'd need.
PostPosted: Sun May 11, 2008 6:58 pm    Post subject: Reply with quote
Now your not suppose to be racing school bus' Laughing
Nice looking rockers. I want to go with some, but need some green first.
PostPosted: Tue May 13, 2008 4:31 pm    Post subject: Reply with quote
Shiny new parts arrived. These things are freaking heavy actually. Seem to be nice quality.
[/img]
PostPosted: Tue May 13, 2008 6:40 pm    Post subject: Reply with quote
Well there's evidence on the studs that the comp magnum rockers were rubbing. Not sure if it was the pivot ball or the rocker itself though. I don't see any sign of rubbing on the rocker, but theres definate wear on pushrod side of the studs. Comp never tells you how much lift a long slot rocker will handle. Another thing I noticed is the comp rockers have a whole lot more side play in them then the jegs rockers. Both sets are self aligning. I'd say the comps have more then 1/8" side play, and the jegs are probably half that. The jegs use a roller tip with side rails built into the roller. The comps have a smooth roller and edges built into the rocker itself for the alignment feature. Looking in jegs catalog, it looks like comp may be going to the railed roller now as well on the magnum rockers. I would think this would keep the side clearances much tighter. I'm hoping by losing all this slop, and whatever was rubbing the studs, my motor will end up much quieter. It's been quite noisey since I put this cam in, and was never very quiet with the old comp cam either.
