relocating the battery.
jakemk8706
PostPosted: Fri Apr 25, 2008 11:20 am    Post subject: relocating the battery. Reply with quote
so i want to relocate the battery so i can make a cold air intake.
i was just curious on the best method on doing this.
so i was thinking putting the battery (sealed of course) where the spare tire goes. but i just dont know which is the best way to route the cables. either tucked under the car or some how thru the interior.
IDK....just lookin for some suggestions
gas brake dip dip
PostPosted: Fri Apr 25, 2008 11:28 am    Post subject: Reply with quote
look at my v6 sig. I put my battery back in the spare tire well. Don't run the wires outside. Theres more than enough room to run it under the carpet.
PostPosted: Sat Apr 26, 2008 7:24 am    Post subject: Reply with quote
Do you plan on ever taking it to the drag strip?
PostPosted: Sat Apr 26, 2008 7:52 am    Post subject: Reply with quote
it can get spendy to buy the length of 1ga welding cable that runs from the hatch area up to the starter.
And I think you'll have to find a way to mount a disconnect switch somewhere on the outside of the body.
Twilightoptics did this mod about a year or so ago. He could tell ya more about it.
jakemk8706
PostPosted: Sat Apr 26, 2008 10:07 am    Post subject: Reply with quote
ya i do plan on taking it down to PIR one of these days...
why would i need that?
gas brake dip dip
PostPosted: Sat Apr 26, 2008 11:55 am    Post subject: Reply with quote
Alright, If you relocate the battery from the stock location to the rear of the vehicle it's going to need to be contained in an aluminum battery box or sealed off by a firewall. You'll have to have an exterior mounted battery cut off switch that is clearly marked OFF and wired to the alternator to kill all power to the car and engine.
The only plastic battery box that is NHRA legal is the one sold by Moroso. Instead of a switch you can also have a push/pull cut off, that way when you're done racing you can remove the rod so it's not visible from the exterior.
jakemk8706
PostPosted: Sat Apr 26, 2008 7:01 pm    Post subject: Reply with quote
really??? thats kinda lame. i dont wanna have a on/off switch on the back of my car...i guess ill figure something else out.
gas brake dip dip
redlava
PostPosted: Sat Apr 26, 2008 7:38 pm    Post subject: Reply with quote
You could try and get an extra tail light from the junk yard. Then you could mount the switch in the tail light housing. Then when you need the switch at the track put the other tail light housing in.
PostPosted: Sun Apr 27, 2008 6:50 pm    Post subject: Reply with quote
Well I've seen some third gens cut a hole behind the license plate. that way they can flip down the plate and mount on of those push pull type of cut off switched behind it. When you're done racing remove the rod, flip up the plate and you'd never even know you had a cut off switch back there.
here's a good option too...
http://www.thirdgen.org/techboard/electronics/408298-lets-see-your-remote.html?highlight=battery+switch+off+cut
and another good one
http://www.thirdgen.org/techboard/body/321848-nhra-kill-switch.html
PostPosted: Sun Apr 27, 2008 9:33 pm    Post subject: Reply with quote
http://www.thirdgen.org/techboard/attachments/body/103136d1127166242-nhra-kill-switch-panel-off.jpg
that's what I did. Works great.
PostPosted: Mon Apr 28, 2008 7:28 am    Post subject: Reply with quote
Why does he have to have a battery cutoff? Is it because the battery has been relocated AND he wants to run the strip?
PostPosted: Mon Apr 28, 2008 8:49 am    Post subject: Reply with quote
Yes, it's an NHRA rule.
jakemk8706
PostPosted: Mon Apr 28, 2008 5:37 pm    Post subject: Reply with quote
ya i like that one behind that cover plate.
but the other thing is, can it be in the wheel well? because i found this.
http://www.hawksthirdgenparts.com/index.asp?PageAction=VIEWPROD&ProdID=1677
but this prob isn't track legal huh?
gas brake dip dip
PostPosted: Mon Apr 28, 2008 10:20 pm    Post subject: Reply with quote
The only track legal battery box that I am aware of, is the Morroso sealed one.
--John
PostPosted: Tue Apr 29, 2008 6:22 am    Post subject: Reply with quote
Has to be a SEALED battery box that is NHRA approved.
You might get yourself a rulebook if you're planning to run the drags on any kind of regular basis.
