Mangus Member
Joined: 10 Jan 2004 Posts: 255 Location: @computer in garage (Bothell)
1989 Pontiac Trans Am
Posted: Tue Dec 11, 2007 9:16 pm Post subject: |
Aaron -
If you find yourself up here towards Seattle, let me know. I'll walk you through it all and have you tuning and logging for your drive back to Tacoma. |
Posted: Tue Dec 11, 2007 9:47 pm Post subject: |
Pfft. If that's all it took then I'll call you as soon as my trans is back in the bird.  |
alloy T56 Elitist
Posted: Wed Dec 12, 2007 4:38 am Post subject: |
| Twilightoptics wrote: | | Dan I didn't have to change anything to burn those chips with the burn 1 if they were stacked right from tunerpro. |
I didn't stack mine, I just read the instructions from Moates and no stacking required. One less step to bother with, one less thing to go wrong. |
Posted: Wed Dec 12, 2007 7:10 am Post subject: |
I see. Never did it withoutstacking.
Well Aaron it's possible your definition file is bad, your original bin file is bad, or you have the chip in backward!
If you stack it can be the same file name. |
Posted: Wed Dec 12, 2007 9:48 am Post subject: |
With the last chip I tried I actually tried dropping it into the ZIF socket both ways, so I'm pretty sure I don't have it in backwards.
It never occured to me that my XDF might be corrupt. I've tried several BIN files, some stock, some I edited. I was only using 6E files since I deleted the cold start, and it's fairly hard to start the car without it in good weather, much less the 38* outside temp right now.
I think I'm just gonna start trying some 32 BINs. |
Posted: Wed Dec 12, 2007 10:23 am Post subject: |
| Did you turn it on with it in backwards? I believe that toasts the chip. |
Posted: Wed Dec 12, 2007 10:27 am Post subject: |
AHH! IT WORKS!
Burnt a bone stock 32 ABWT BIN (basically stock for the car, except different rear gear) threw codes, turned the SES light off, cranked and fired perfectly. Idles smooth, tons more torque.
I don't know what the difference is, but I stomped it at 2500 in second and went sliding sideways.
Now I'm gonna have to figure out why the 6E didn't fly, but I'm late for work. |
Posted: Wed Dec 12, 2007 10:48 am Post subject: |
Posted: Wed Dec 12, 2007 10:16 pm Post subject: |
10 hour shift, meh. No time to play with my toys.
Tried a new 6E BIN tonight and it flashed the SES like it should. Didn't start it though... damn neighbors. |
Mangus Member
Posted: Thu Dec 13, 2007 6:46 am Post subject: |
| If you don't have VATS, don't forget to disable it in the 6E bin. |
