ALDL problems (Schultzy or Paul?)
Goto page Previous  1, 2
Mangus
1989 Pontiac Trans Am
PostPosted: Tue Dec 11, 2007 9:16 pm    Post subject: Reply with quote
Aaron -
If you find yourself up here towards Seattle, let me know. I'll walk you through it all and have you tuning and logging for your drive back to Tacoma.
PostPosted: Tue Dec 11, 2007 9:47 pm    Post subject: Reply with quote
Pfft. If that's all it took then I'll call you as soon as my trans is back in the bird. Laughing
PostPosted: Wed Dec 12, 2007 4:38 am    Post subject: Reply with quote
Dan I didn't have to change anything to burn those chips with the burn 1 if they were stacked right from tunerpro.
I didn't stack mine, I just read the instructions from Moates and no stacking required. One less step to bother with, one less thing to go wrong.
PostPosted: Wed Dec 12, 2007 7:10 am    Post subject: Reply with quote
I see. Never did it withoutstacking.
Well Aaron it's possible your definition file is bad, your original bin file is bad, or you have the chip in backward!
If you stack it can be the same file name.
PostPosted: Wed Dec 12, 2007 7:41 am    Post subject: Reply with quote
Are you sure you got a good bin? I would try to reburn a stock bin back on the chip you are having troubles with. I remember I had a problem when I first started doing mine, I had to set the start:end to 000000 and 007FFF. Once I did that everything worked.
Can you read chips? Do you have the USB burner? Do you have the port settings correct for the burner?
How to get it up and running
How to program chips and stuff once its running
PostPosted: Wed Dec 12, 2007 9:48 am    Post subject: Reply with quote
With the last chip I tried I actually tried dropping it into the ZIF socket both ways, so I'm pretty sure I don't have it in backwards. Embarassed Embarassed
It never occured to me that my XDF might be corrupt. I've tried several BIN files, some stock, some I edited. I was only using 6E files since I deleted the cold start, and it's fairly hard to start the car without it in good weather, much less the 38* outside temp right now.
I think I'm just gonna start trying some 32 BINs.
PostPosted: Wed Dec 12, 2007 10:23 am    Post subject: Reply with quote
Did you turn it on with it in backwards? I believe that toasts the chip.
PostPosted: Wed Dec 12, 2007 10:27 am    Post subject: Reply with quote
AHH! IT WORKS! Get down and Boogie!
Burnt a bone stock 32 ABWT BIN (basically stock for the car, except different rear gear) threw codes, turned the SES light off, cranked and fired perfectly. Idles smooth, tons more torque.
I don't know what the difference is, but I stomped it at 2500 in second and went sliding sideways. Very Happy
Now I'm gonna have to figure out why the 6E didn't fly, but I'm late for work.
PostPosted: Wed Dec 12, 2007 10:48 am    Post subject: Reply with quote
Thumbs up
PostPosted: Wed Dec 12, 2007 10:16 pm    Post subject: Reply with quote
10 hour shift, meh. No time to play with my toys. Sad
Tried a new 6E BIN tonight and it flashed the SES like it should. Didn't start it though... damn neighbors.
Mangus
PostPosted: Thu Dec 13, 2007 6:46 am    Post subject: Reply with quote
If you don't have VATS, don't forget to disable it in the 6E bin.
Page 2 of 2
