Posted: Mon Feb 05, 2007 11:19 pm Post subject: And so our story begins: |
Ya know, you really start to get faster at this! Plus the AIR was big help with the head bolts. Started at 645pm tonight, finished at 845pm. Wasn't russian either!
Good news is, no evidence of collision!
Gotta find a spring compressor to play around with the valves while I wait for $$ to fix. |
90droptoproc Member
Posted: Tue Feb 06, 2007 1:25 am Post subject: |
nice work, awfull quick too _________________
Posted: Tue Feb 06, 2007 8:47 am Post subject: |
| What is the actual problem Paul? |
Posted: Tue Feb 06, 2007 9:51 am Post subject: |
| rjmcgee wrote: | | What is the actual problem Paul? |
You think you beat me! That's the problem!
Severely leaky valves!
Put air in cyl #1 to pop the springs off and inspect.... air coming out the intake.
Checked #7... air REALLLY coming out the intake.
Bent valves or a thin grind that didn't last.
No evidence of valve contact though, so that's promising.
I do have a spare set of valves. Need About $250 to fix assuming I don't need to BUY valves. $150 for the grind roughly, and $90 for new springs.
Plus gaskets.
Found one of my headers was leaking pretty bad. Gonna try and find some grade 8 header bolts so I dont round the ends. Maybe even find some with 5/16 head or something to get a ratchet or box end wrench in there. |
Posted: Tue Feb 06, 2007 2:00 pm Post subject: |
this and a socket driven allen wrench and you can get those mothers as tight as you like.  |
Posted: Tue Feb 06, 2007 2:57 pm Post subject: |
Do these and never screw with them again.
Posted: Tue Feb 06, 2007 5:10 pm Post subject: |
Don't have a problem with them coming loose. Actually it'd be more PITA to use the locks than not.
I have a slight problem with getting to the head of the bolt.
Tony those are great, except the head looks too big for a few of my trouble bolt holes. I had to grind the flange down on a few to make them fit past the primary. |
Posted: Wed Feb 07, 2007 12:53 am Post subject: |
| hmm... are our primarys the same size? i'll have to see if they fit on mine. realy should put them on one of these days. |
Posted: Wed Feb 07, 2007 9:55 am Post subject: |
Your primarys are bigger. My tube design is different. I think the actual wall of my headers might be thicker also. I had no problem welding the air tubes flush.
You have 1 3/4 I have 1 5/8 |
Posted: Wed Feb 07, 2007 11:13 am Post subject: |
| 355 with a Holley Stealth Ram |
Posted: Thu Feb 08, 2007 4:53 pm Post subject: |
Forgive my ignorance, but what is that sheet metal looking thing in the middle of the lifter valley?  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Thu Feb 08, 2007 5:01 pm Post subject: |
| RSFreak wrote: | Forgive my ignorance, but what is that sheet metal looking thing in the middle of the lifter valley?  |
It keeps the oil from splashing up onto his intake, this is to try to keep the intake cooler. I think it is called a "Lifter Valley Cover or Pan, or something".
--john |
Posted: Thu Feb 08, 2007 5:09 pm Post subject: |
| Dewey316 wrote: | | RSFreak wrote: | Forgive my ignorance, but what is that sheet metal looking thing in the middle of the lifter valley?  |
--john |
And in all acutality I don't think it does much for keeping oil off the intake. I don't know really how it would get up there. The biggest thing I have it for, is if a rocker comes off, or a stud breaks, etc this piece of metal keeps the lifter in it's bore.
If the lifter was thrown out of the bore, oil wouldn't get to the rest of things, and cause major damage. It's saved my rear several times!
It's the Moroso Lifter Valley Oil Baffle.
Was like $20 and WELL Worth it. Trim to fit. |
