And so our story begins:
PostPosted: Mon Feb 05, 2007 11:19 pm    Post subject: And so our story begins: Reply with quote
Ya know, you really start to get faster at this! Plus the AIR was big help with the head bolts. Started at 645pm tonight, finished at 845pm. Wasn't russian either! Laughing
Good news is, no evidence of collision!
Gotta find a spring compressor to play around with the valves while I wait for $$ to fix.
90droptoproc
PostPosted: Tue Feb 06, 2007 1:25 am    Post subject: Reply with quote
nice work, awfull quick too
PostPosted: Tue Feb 06, 2007 8:47 am    Post subject: Reply with quote
What is the actual problem Paul?
PostPosted: Tue Feb 06, 2007 9:51 am    Post subject: Reply with quote
You think you beat me! That's the problem! Laughing
Severely leaky valves!
Put air in cyl #1 to pop the springs off and inspect.... air coming out the intake.
Checked #7... air REALLLY coming out the intake.
Bent valves or a thin grind that didn't last.
No evidence of valve contact though, so that's promising.
I do have a spare set of valves. Need About $250 to fix assuming I don't need to BUY valves. $150 for the grind roughly, and $90 for new springs.
Plus gaskets.
Found one of my headers was leaking pretty bad. Gonna try and find some grade 8 header bolts so I dont round the ends. Maybe even find some with 5/16 head or something to get a ratchet or box end wrench in there.
PostPosted: Tue Feb 06, 2007 2:00 pm    Post subject: Reply with quote
this and a socket driven allen wrench and you can get those mothers as tight as you like. Wink
PostPosted: Tue Feb 06, 2007 2:57 pm    Post subject: Reply with quote
Do these and never screw with them again.
PostPosted: Tue Feb 06, 2007 5:10 pm    Post subject: Reply with quote
Don't have a problem with them coming loose. Actually it'd be more PITA to use the locks than not.
I have a slight problem with getting to the head of the bolt.
Tony those are great, except the head looks too big for a few of my trouble bolt holes. I had to grind the flange down on a few to make them fit past the primary.
PostPosted: Wed Feb 07, 2007 12:53 am    Post subject: Reply with quote
hmm... are our primarys the same size? i'll have to see if they fit on mine. realy should put them on one of these days.
PostPosted: Wed Feb 07, 2007 9:55 am    Post subject: Reply with quote
Your primarys are bigger. My tube design is different. I think the actual wall of my headers might be thicker also. I had no problem welding the air tubes flush.
You have 1 3/4 I have 1 5/8
PostPosted: Wed Feb 07, 2007 10:56 am    Post subject: Reply with quote
what motor and intake setup are you running? Looks interesting.
PostPosted: Wed Feb 07, 2007 11:13 am    Post subject: Reply with quote
355 with a Holley Stealth Ram
PostPosted: Thu Feb 08, 2007 4:53 pm    Post subject: Reply with quote
Forgive my ignorance, but what is that sheet metal looking thing in the middle of the lifter valley? Confused
PostPosted: Thu Feb 08, 2007 5:01 pm    Post subject: Reply with quote
It keeps the oil from splashing up onto his intake, this is to try to keep the intake cooler. I think it is called a "Lifter Valley Cover or Pan, or something".
--john
PostPosted: Thu Feb 08, 2007 5:09 pm    Post subject: Reply with quote
--john
And in all acutality I don't think it does much for keeping oil off the intake. I don't know really how it would get up there. The biggest thing I have it for, is if a rocker comes off, or a stud breaks, etc this piece of metal keeps the lifter in it's bore.
If the lifter was thrown out of the bore, oil wouldn't get to the rest of things, and cause major damage. It's saved my rear several times!
It's the Moroso Lifter Valley Oil Baffle.
Was like $20 and WELL Worth it. Trim to fit.
