Wheel torque geek out.
PostPosted: Tue Aug 01, 2006 8:07 am    Post subject: Wheel torque geek out. Reply with quote
Okay, so I geeked out. I calculated the wheel torque and mph for my auto and the WCT5 that is sitting on the shop floor. This is using the stock sized tire of diameter 25.6 (245/50r16) and 4.11 gears.
    WC-T5
    2.95---2269.3---34.6
    1.94---1492.4---52.6
    1.34---1030.8---76.2
    1.00----769.3---102.1
    0.74---569.2---138.0
    Auto
    3.06---2353.9---33.4
    1.63---1253.9---62.6
    1.00---769.3---102.1
    0.78---600.0---130.9
    0.70---538.5----145.9
Looks like the manual would be faster, not to mention lighter and I wouldn't have an auto. I autocross this car, so do you think I could have a problem shifting or getting it in gear? I'm going to have to swap input shafts and the bellhousing to make it fit my V6 (no biggie right?).
PostPosted: Tue Aug 01, 2006 8:15 am    Post subject: Reply with quote
If you auto-x manual is the way to go. I normaly just leave it in 2nd and go, but depending on the car and course, you may need to hit third, here or there.
You also don't have to worry about it downshifting on you mid corner, you pick what gear your in.
PostPosted: Tue Aug 01, 2006 8:20 am    Post subject: Reply with quote
I'm just worried about mis-shifts and bad syncro's. but if I mate a WC T5 to my V6, I think the tranny would whoop on my motor! All 200ft.lbs....
I tried to fix the spacing by the forum engine takes all the tabs and spaces out inbetween words. Grrr...
PostPosted: Tue Aug 01, 2006 8:29 am    Post subject: Reply with quote
I can't answer that one for you, if the syncro's are good, that shouldn't be an issues, and if your right hand / left foot cordination is good, mis-shifts shouldn't be an issue. I guess that part is a matter of how much you trust yourself as a driver.
PostPosted: Tue Aug 01, 2006 8:48 am    Post subject: Reply with quote
but a T5 would be faster tho huh? Lighter, better gearing, and more power transfer to the wheels?
PostPosted: Tue Aug 01, 2006 9:06 am    Post subject: Reply with quote
Its hard to say, it may not launch as well, and it doesn't have the same torque multipication as a torque converter and auto.
For auto-x use, I think a manual is better, as you can feather the clutch, and manualy pick the gear you are in. It SHOULD be faster around an auto-x course, with a good driver. Go with what YOU want. In auto-x, usualy the driver is the weak link of the car. Concentrate on making yourself faster, before you worry about making the car faster.
--john
PostPosted: Tue Aug 01, 2006 3:21 pm    Post subject: Reply with quote
--john
Wise words, I auto crossed last summer in my 87 acura integra with a 5 spd and because i was a decent driver I was able to woop up on some much faster cars because I was a better driver then them. Practice lots and just have fun with it. I would say go with the manual for auto cross though.
PostPosted: Wed Aug 02, 2006 7:00 pm    Post subject: Reply with quote
Manual= Thumbs up
I don't know about the WCT5's Gear ratio between first and second, but I THINK that with the earlier ones the V6 got a 3.27:1 and the V8's got a 2.95:1. I seem to remember reading that somewhere....but maybe I"m just getting numbers confused.
I'm curious if the T-5 on my 2001 is a 14 spline V6 transmission like the ones on the 60 degree V6's or if its something different because my 3.8 is a Buick motor. I suppose I could take it out and find out....but I dont feel like doing that....
PostPosted: Thu Aug 03, 2006 7:04 am    Post subject: Reply with quote
I heard that too, the V6 T-5's are different than the V8 T-5's. The numbers above are for a V8 T-5. I really don't know why I'm putting it in, other than the fact that I can't find a V6 T-5 and I have a WC T-5 sitting here. I would imagine that the Buick V6 is way different than the chevy's. I've never heard of anyone putting a chevy 700r4 on a 3.8 so I know the bellhousings are different, probably the splines too.
PostPosted: Thu Aug 03, 2006 4:23 pm    Post subject: Reply with quote
*shruggs*
I don't really know. I know they used both a T-5 and a 4L60-E on later base model camaros. Mine's a Gen II 3.8L which uses DIS (Uses Coil packs) instead of having a distributor or an opti-spark like distributor.
Your WCT5 is a V8 transmission?
I see V6 transmissions in the Boneyard all the time still in the cars.....
PostPosted: Thu Aug 03, 2006 8:42 pm    Post subject: Reply with quote
the junkyards up here suck. I'm from bremerton and I miss the old Eastside Auto. You could find anything there and it was cheap. Ahh the good old days....
but ya, the transmissions were the same V6-V8 as far as I know, exept the bellhousings and that 1st gear. The only cool T-5 was the World Class, which was rated for 50 more hp and tq (beefier internals).
I'm amazed you did the 3.8 swap! are you going to make it a 3.8T????
PostPosted: Thu Aug 03, 2006 9:45 pm    Post subject: Reply with quote
Laughing Laughing
Chris, I assume you're talking about your 4th gen, right?
PostPosted: Fri Aug 04, 2006 6:45 am    Post subject: Reply with quote
Oh, well a 3.8 4th gen wouldn't be that special.....
PostPosted: Fri Aug 04, 2006 8:25 am    Post subject: Reply with quote
Aaron's right, I'm speaking of the 4th gen. Both my 3rd gen's are V8's in need of some help...but any money that I have is going to school for now.
