What do you guys use to clean
budgetracer
PostPosted: Sun May 07, 2006 12:17 am    Post subject: What do you guys use to clean Reply with quote
20 plus years of grime and gunk out of your engine bay? I'm slowly getting my engine bay all cleaned out after pulling the motor. I've been using a mix of gunk and heavy duty degreaser with wire brushes but it's taking forever. Any other suggestions? I plan on doing under the car too and keep in mind I don't have access to a hose.
PostPosted: Sun May 07, 2006 7:40 am    Post subject: Reply with quote
gas or carb cleaner works very well but very expensive
kurfbird
PostPosted: Sun May 07, 2006 7:42 am    Post subject: Simple green Reply with quote
Simple green. A pressure washer like at a car wash (Self Wash) place works well also
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Sun May 07, 2006 9:26 am    Post subject: Reply with quote
Castrol Superclean works awesome. Be careful if you want to keep the paint on there though, if you leave it sit too long it will remove that too.
PostPosted: Sun May 07, 2006 1:31 pm    Post subject: Re: Simple green Reply with quote
Same here. I rarely clean the engine compartment, but that stuff works wonders if you use it right. Plus it's not going to kill you to breathe it, which is a nice bonus. Razz
PostPosted: Sun May 07, 2006 2:39 pm    Post subject: Reply with quote
You need a hose, super clean, and a brush of sorts.
PostPosted: Mon May 08, 2006 4:10 pm    Post subject: Re: Simple green Reply with quote
But if you don't kill brain cells it isn't any fun! Laughing I always used laquer thinner, it works alright.
budgetracer
PostPosted: Mon May 08, 2006 8:54 pm    Post subject: Reply with quote
thanks for all the input guys, cleaning is coming along a little better, just been working to many hours to get alot of work done. Engine bay is about three forths done and I started installing my poly bushings!
