budgetracer Member
Posted: Sun May 07, 2006 12:17 am Post subject: What do you guys use to clean |
| 20 plus years of grime and gunk out of your engine bay? I'm slowly getting my engine bay all cleaned out after pulling the motor. I've been using a mix of gunk and heavy duty degreaser with wire brushes but it's taking forever. Any other suggestions? I plan on doing under the car too and keep in mind I don't have access to a hose. |
BigDaddyVu 12sec Club
Posted: Sun May 07, 2006 7:40 am Post subject: |
gas or carb cleaner works very well but very expensive _________________
kurfbird Member
Posted: Sun May 07, 2006 7:42 am Post subject: Simple green |
Simple green. A pressure washer like at a car wash (Self Wash) place works well also _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
Posted: Sun May 07, 2006 9:26 am Post subject: |
| Castrol Superclean works awesome. Be careful if you want to keep the paint on there though, if you leave it sit too long it will remove that too. |
Posted: Sun May 07, 2006 1:31 pm Post subject: Re: Simple green |
| kurfbird wrote: | | Simple green. A pressure washer like at a car wash (Self Wash) place works well also |
Same here. I rarely clean the engine compartment, but that stuff works wonders if you use it right. Plus it's not going to kill you to breathe it, which is a nice bonus.  |
Posted: Sun May 07, 2006 2:39 pm Post subject: |
| You need a hose, super clean, and a brush of sorts. |
Posted: Mon May 08, 2006 4:10 pm Post subject: Re: Simple green |
| Asdfga3 wrote: | | kurfbird wrote: | | Simple green. A pressure washer like at a car wash (Self Wash) place works well also |
But if you don't kill brain cells it isn't any fun! I always used laquer thinner, it works alright. _________________ 1983 Z-28 5.7 LT1, T56, Headman headers, BW 9 Bolt Posi Disc, WS6 suspension
budgetracer Member
Posted: Mon May 08, 2006 8:54 pm Post subject: |
| thanks for all the input guys, cleaning is coming along a little better, just been working to many hours to get alot of work done. Engine bay is about three forths done and I started installing my poly bushings! |
