Help on holley carb
Goto page Previous  1, 2
PostPosted: Thu Nov 15, 2012 12:11 pm    Post subject: Reply with quote
Definatly easier. My 70 practically has a zipper.
PostPosted: Fri Nov 16, 2012 7:00 pm    Post subject: Reply with quote
Whatever you do, don't get an Autozone reman.
Rebuilding a motocraft holley for a friend of a friend. It was missing the Accelerator pump needle, AND the secondary metering intermediate plate, and various o-rings/gaskets.
No wonder it ran like crap. I'm surprised it ran at all!
PostPosted: Sat Nov 17, 2012 10:43 am    Post subject: Reply with quote
Block out, dizzy out. The dizzy snapped just above where it touches the lifter valley.
Lots of sludge inside the motor.
Do need an intake, I posted in the wanted section. But I'm also checking the truck board as well.
PostPosted: Wed Nov 21, 2012 7:59 pm    Post subject: Reply with quote
block cleaned, painted, 1 lifter replaced, new oil pump, sludge cleaned out. New parts in and sitting on the floor. Ready for a productive 4 day weekend Very Happy
PostPosted: Sun Nov 25, 2012 2:11 pm    Post subject: Reply with quote
It runs Very Happy
PostPosted: Sun Nov 25, 2012 2:18 pm    Post subject: Reply with quote
http://www.youtube.com/watch?v=fBWQkUSFfp0&feature=youtu.be
PostPosted: Sun Nov 25, 2012 3:13 pm    Post subject: Reply with quote
I think you're missing a fan spacer or something!
PostPosted: Sun Nov 25, 2012 3:33 pm    Post subject: Reply with quote
I think the cross member I installed moved the motor back? The dizzy is RIGHT up against the firewall.
Plus he fan is actually bigger in dia then the opening in the shroud.
Another thing, this whole motor is from an elcamino, not a truck. So that is likely a fan for it, rather then truck. Yet the shroud I jacked off a 72 chevy truck.
PostPosted: Sun Nov 25, 2012 4:54 pm    Post subject: Reply with quote
Ah.. there's actually 3 positions that the motor mount plates can be bolted into. Sounds like you have yours in the 6 cylinder position. The v/8 position is further forward. I'd use whichever setup your drivelines are made for.
PostPosted: Sun Nov 25, 2012 5:01 pm    Post subject: Reply with quote
I'm with stupid
Also if you use the mounts from that El Camino it will sit lower than the truck mounts.
PostPosted: Sun Nov 25, 2012 5:44 pm    Post subject: Reply with quote
I have a full aftermarket cross member with motor mounts. It will only bolt in one position.
PostPosted: Sun Dec 09, 2012 6:39 pm    Post subject: Reply with quote
http://www.youtube.com/watch?v=SjleM1oVANo&feature=youtu.be
http://www.youtube.com/watch?v=Sa5LKiq0Fh0&feature=youtu.be
Very Happy
PostPosted: Fri Dec 21, 2012 4:37 pm    Post subject: Reply with quote
Wow Jay, you went all out. How is it doing now? Take it off of any sweet jumps? Razz
PostPosted: Fri Dec 21, 2012 7:12 pm    Post subject: Reply with quote
I went to run it off its own gas tank (electric tbi pump) rather then a redneck gas tank hanging from the front frame horns...... blew out the gaskets.
So not sure whats up with my inline regulator that was SUPPOSE to be preset at 7psi, that blew the gaskets somewhere around 10-12.
So other then driving it around the neighborhood once. It hasnt really moved.
:edit: btw, since your on my facebook page, I keep it fairly uptodate with pictures. chevymad or whoever else that might be on the 67-72 board also has a way to keep uptodate.
PostPosted: Fri Dec 21, 2012 7:18 pm    Post subject: Reply with quote
Same me on that board.
PostPosted: Fri Dec 21, 2012 7:20 pm    Post subject: Reply with quote
go to the jimmy project board, "30years sitting".
Page 2 of 2
