BluFbdy Member
Posted: Thu Mar 08, 2012 9:43 pm Post subject: 2.8 v6 |
so I'm hunting around for a new motor to swap into my wife's car, valve guides are bad and from what I can tell a good v6 will be cheaper than getting the heads worked
anyone got a solid one that runs? or a good set of heads for a 2.8??? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
kurfbird Member
Posted: Fri Mar 09, 2012 12:32 am Post subject: Heads v6 |
I ahve a good set of heads from a 3.1 will work on a 2.8
Make and offer _________________ kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com |
BluFbdy Member
Posted: Fri Mar 09, 2012 12:34 am Post subject: |
idk what that'll do to the 2.8 cuz I know they're the same block just bored and stroked... are there any ill effects? _________________ If you expect a kick to the balls and get a slap to the face its still a victory
kurfbird Member
Posted: Fri Mar 09, 2012 12:37 am Post subject: effects |
None that I am aware of probably the same heads. I cant make it down you way till next weekend
I am moving out of my mobile home this weekend and having a new manufactrured home put on site . So putting everything in storage _________________ kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
BluFbdy Member
Posted: Fri Mar 09, 2012 12:46 am Post subject: |
how's 75 to 100 sound? I can probly make it up your way, uses to live up off sr20 and I kinda miss it up there lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
