2.8 v6
BluFbdy
PostPosted: Thu Mar 08, 2012 9:43 pm    Post subject: 2.8 v6 Reply with quote
so I'm hunting around for a new motor to swap into my wife's car, valve guides are bad and from what I can tell a good v6 will be cheaper than getting the heads worked
anyone got a solid one that runs? or a good set of heads for a 2.8???
kurfbird
PostPosted: Fri Mar 09, 2012 12:32 am    Post subject: Heads v6 Reply with quote
I ahve a good set of heads from a 3.1 will work on a 2.8
Make and offer
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
BluFbdy
PostPosted: Fri Mar 09, 2012 12:34 am    Post subject: Reply with quote
idk what that'll do to the 2.8 cuz I know they're the same block just bored and stroked... are there any ill effects?
kurfbird
PostPosted: Fri Mar 09, 2012 12:37 am    Post subject: effects Reply with quote
None that I am aware of probably the same heads. I cant make it down you way till next weekend
I am moving out of my mobile home this weekend and having a new manufactrured home put on site . So putting everything in storage
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
BluFbdy
PostPosted: Fri Mar 09, 2012 12:46 am    Post subject: Reply with quote
how's 75 to 100 sound? I can probly make it up your way, uses to live up off sr20 and I kinda miss it up there lol
