Posted: Fri Dec 02, 2011 6:02 am Post subject: What to make out of alumn. |
So I have a welder and they make a kit to heliarc alumn. I have to fix my intake when I do a cam.
So I'm trying to think of other things I can build with this. Doesnt have to be car stuff.
rear bumper bracing
trans bracket?
Nice stb?
air intake tube
Whatelse? |
nonsensekid20 Member
Posted: Fri Dec 02, 2011 9:37 pm Post subject: |
| Cross member for t56, subframe connectors. Just throwin some stuff out. lol |
Posted: Fri Dec 02, 2011 10:04 pm Post subject: |
| nonsensekid20 wrote: | | Cross member, subframe connectors |
Building a little fishing boat or airplane or something out there?
@ Jay: I'd have my sights fixed firmly on the front and rear crash bars. Those bishes are heavy. |
Posted: Fri Dec 02, 2011 11:11 pm Post subject: |
Build me some ITB's  _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Sat Dec 03, 2011 4:46 am Post subject: |
I already have a front crash bar. But yea, rear was on my list.
ITB's? |
Posted: Sat Dec 03, 2011 9:51 am Post subject: |
Individual Throttle Bodies.  _________________
Posted: Wed Dec 28, 2011 12:12 pm Post subject: |
So, since were slow at work and the junkyard was about to crush a 91 camaro. I snagged the rear bumper, took some measurements and designed a rear crash bar.
Almost stock design.
Stock weights in at 27lbs with the grid on it. If my calculations are correct, this should tip in at 12-13 w/o the grid. Material already ordered. |
IROCDave Member
Posted: Fri Jan 27, 2012 7:41 am Post subject: |
started zapping it together last night. My 3rd try at "welding" aluminum.
Posted: Fri Jan 27, 2012 8:36 am Post subject: |
Not bad to start! _________________ A redline a day keeps the carbon away! |
Posted: Fri Jan 27, 2012 9:38 am Post subject: |
looks pretty clean! Better than most Made in china crap i see.
Posted: Fri Jan 27, 2012 10:29 am Post subject: |
Thanks.
My first attempt was just learning and looked like some major pigon poop.
2nd was to fix my intake, and I was going to fill a void and be secure. Looked like crap tell I ground on it.
This is my 3rd. I think I'm getting better. But I still have more to go on this project. |
Posted: Fri Jan 27, 2012 7:37 pm Post subject: |
All test bolted up and fits Was a little off on my measurements, but if I have to build one again, I know what needs changed.
Trying to decide if I should paint,just clear it, or leave it raw? |
Posted: Fri Jan 27, 2012 9:10 pm Post subject: |
That old-timey fuzzy scale is great!  |
Posted: Sat Jan 28, 2012 3:55 pm Post subject: |
All put back together.
If I was to do this again and didnt want strap-down hook points. I think I could make this down to 10lbs.
So what should I try next?  |
Posted: Sat Jan 28, 2012 4:02 pm Post subject: |
| 91RSVert wrote: | So what should I try next?  |
Front crash bar? STB?
Good to see some fellow weight reducers in the crew.  |
Posted: Sat Jan 28, 2012 4:27 pm Post subject: |
I already have an alumn front crash bar, and a spare to back it up.
Thought about STB. But wondering if alumn flexes to much to even make it worth it?
Everything I keep coming up with is on the rear of the car Ive seriously thought about an alumn catback to the muffler. |
BluFbdy Member
Posted: Tue Jan 31, 2012 3:41 am Post subject: |
That's a great idea for the crash bars, my front one is jacked from my tree incident its too bad you're not local I'd definitely buy one off of you, I would.t care except the passenger side of my chin spoiler is pulled in a bit, can't tell until you compare sides but its still annoying, does your front design have the same holes for the gfx? I'm always up to losing weight where I can lol _________________ If you expect a kick to the balls and get a slap to the face its still a victory
Posted: Tue Jan 31, 2012 5:46 am Post subject: |
| If you need a front crash bar, start hunting the 82-84 camaros. Some models of them came with the alumns. Then just a slight trim on the plastic grid and its taken care of. |
Posted: Tue Jan 31, 2012 7:35 am Post subject: |
| Jay do you have a weight on the factory aluminum piece? I have never weighed one but they seem overbuilt and you could probably shave a few pounds building one yourself. |
