What to make out of alumn.
PostPosted: Fri Dec 02, 2011 6:02 am    Post subject: What to make out of alumn. Reply with quote
So I have a welder and they make a kit to heliarc alumn. I have to fix my intake when I do a cam.
So I'm trying to think of other things I can build with this. Doesnt have to be car stuff.
rear bumper bracing
trans bracket?
Nice stb?
air intake tube
Whatelse?
nonsensekid20
PostPosted: Fri Dec 02, 2011 9:37 pm    Post subject: Reply with quote
Cross member for t56, subframe connectors. Just throwin some stuff out. lol
PostPosted: Fri Dec 02, 2011 10:04 pm    Post subject: Reply with quote
91RSVert wrote:
alumn
nonsensekid20 wrote:
Cross member, subframe connectors
Building a little fishing boat or airplane or something out there? Razz
@ Jay: I'd have my sights fixed firmly on the front and rear crash bars. Those bishes are heavy.
PostPosted: Fri Dec 02, 2011 11:11 pm    Post subject: Reply with quote
Build me some ITB's Very Happy
PostPosted: Sat Dec 03, 2011 4:46 am    Post subject: Reply with quote
I already have a front crash bar. But yea, rear was on my list.
ITB's?
PostPosted: Sat Dec 03, 2011 9:51 am    Post subject: Reply with quote
Individual Throttle Bodies. Very Happy
PostPosted: Wed Dec 28, 2011 12:12 pm    Post subject: Reply with quote
So, since were slow at work and the junkyard was about to crush a 91 camaro. I snagged the rear bumper, took some measurements and designed a rear crash bar.
Almost stock design.
Stock weights in at 27lbs with the grid on it. If my calculations are correct, this should tip in at 12-13 w/o the grid. Material already ordered.
IROCDave
PostPosted: Wed Dec 28, 2011 3:04 pm    Post subject: Reply with quote
http://www.hogansracingmanifolds.com/index.aspx
PostPosted: Fri Jan 27, 2012 7:41 am    Post subject: Reply with quote
started zapping it together last night. My 3rd try at "welding" aluminum.
PostPosted: Fri Jan 27, 2012 8:36 am    Post subject: Reply with quote
Not bad to start!
PostPosted: Fri Jan 27, 2012 9:38 am    Post subject: Reply with quote
looks pretty clean! Better than most Made in china crap i see. Smile
PostPosted: Fri Jan 27, 2012 10:29 am    Post subject: Reply with quote
Thanks.
My first attempt was just learning and looked like some major pigon poop.
2nd was to fix my intake, and I was going to fill a void and be secure. Looked like crap tell I ground on it.
This is my 3rd. I think I'm getting better. But I still have more to go on this project.
PostPosted: Fri Jan 27, 2012 7:37 pm    Post subject: Reply with quote
All test bolted up and fits Very Happy Was a little off on my measurements, but if I have to build one again, I know what needs changed.
Trying to decide if I should paint,just clear it, or leave it raw?
PostPosted: Fri Jan 27, 2012 9:10 pm    Post subject: Reply with quote
That old-timey fuzzy scale is great! Thumbs up
PostPosted: Sat Jan 28, 2012 3:55 pm    Post subject: Reply with quote
All put back together. Very Happy
If I was to do this again and didnt want strap-down hook points. I think I could make this down to 10lbs.
So what should I try next? Twisted Evil
PostPosted: Sat Jan 28, 2012 4:02 pm    Post subject: Reply with quote
Front crash bar? STB?
Good to see some fellow weight reducers in the crew. Yup yup
PostPosted: Sat Jan 28, 2012 4:27 pm    Post subject: Reply with quote
I already have an alumn front crash bar, and a spare to back it up.
Thought about STB. But wondering if alumn flexes to much to even make it worth it?
Everything I keep coming up with is on the rear of the car Laughing Ive seriously thought about an alumn catback to the muffler.
BluFbdy
PostPosted: Tue Jan 31, 2012 3:41 am    Post subject: Reply with quote
That's a great idea for the crash bars, my front one is jacked from my tree incident its too bad you're not local I'd definitely buy one off of you, I would.t care except the passenger side of my chin spoiler is pulled in a bit, can't tell until you compare sides but its still annoying, does your front design have the same holes for the gfx? I'm always up to losing weight where I can lol
PostPosted: Tue Jan 31, 2012 5:46 am    Post subject: Reply with quote
If you need a front crash bar, start hunting the 82-84 camaros. Some models of them came with the alumns. Then just a slight trim on the plastic grid and its taken care of.
PostPosted: Tue Jan 31, 2012 7:35 am    Post subject: Reply with quote
Jay do you have a weight on the factory aluminum piece? I have never weighed one but they seem overbuilt and you could probably shave a few pounds building one yourself.
