Well, this answers the age old question...
PostPosted: Sun Oct 02, 2011 7:58 am    Post subject: Well, this answers the age old question... Reply with quote
Square peg... square hole. Done.
http://www.youtube.com/watch?v=ALiqAXiTQBg
PostPosted: Sun Oct 02, 2011 8:20 am    Post subject: Reply with quote
That's pretty cool.
PostPosted: Sun Oct 02, 2011 8:40 am    Post subject: Reply with quote
Looks like the Chinese got ahold of an old Harry Watt bit from the 60's and went to town. Wink
PostPosted: Sun Oct 02, 2011 8:46 am    Post subject: Reply with quote
I've heard of bits that could do that, but never seen it in action. Obviously a press is a must as that chuck looks a bit off center. Pretty cool stuff.
PostPosted: Sun Oct 02, 2011 10:15 am    Post subject: Reply with quote
The chuck is elliptical, yes. Works like a Wankel engine.
They seemed to have solved the main issue with the Watt mortise bit which is that it left a very small rounded corner, so even though you used it you still had hand work afterwards. That's why you would normally use a chisel bit like so:
PostPosted: Sun Oct 02, 2011 11:32 am    Post subject: Reply with quote
It still leaves rounded corners, the holes are too small to see them, but check out the diagram. They are very minute, but still rounded. Wink
