Posted: Sun Oct 02, 2011 8:20 am Post subject: |
That's pretty cool. _________________ 84 Camaro Z28 - LS1/T56
Posted: Sun Oct 02, 2011 8:40 am Post subject: |
Looks like the Chinese got ahold of an old Harry Watt bit from the 60's and went to town.  |
Posted: Sun Oct 02, 2011 8:46 am Post subject: |
I've heard of bits that could do that, but never seen it in action. Obviously a press is a must as that chuck looks a bit off center. Pretty cool stuff. _________________ 92 Camaro
Posted: Sun Oct 02, 2011 10:15 am Post subject: |
The chuck is elliptical, yes. Works like a Wankel engine.
They seemed to have solved the main issue with the Watt mortise bit which is that it left a very small rounded corner, so even though you used it you still had hand work afterwards. That's why you would normally use a chisel bit like so:
Posted: Sun Oct 02, 2011 11:32 am Post subject: |
It still leaves rounded corners, the holes are too small to see them, but check out the diagram. They are very minute, but still rounded.  _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
