Head Gasket
jchaussee
PostPosted: Wed Aug 17, 2011 6:03 pm    Post subject: Head Gasket Reply with quote
So I have been having an issue with my radiator building a lot of pressure and being a little foamy on top. So I assumed head gaskets. Well I did compression test today and all cylinders were withen 10 psi. So should I assume head gaskets are fine.
PostPosted: Wed Aug 17, 2011 6:12 pm    Post subject: Reply with quote
Only way to know is to remove the spark plugs, and pressure test the cooling system. See if the pressure drops, or stays. Or use some combustion testing dye in a sample of the coolant to see if combustion gas is entering there.
Compression tests are really worthless.
jchaussee
PostPosted: Wed Aug 17, 2011 6:20 pm    Post subject: Reply with quote
At Oriellys they have a radiator pressure testing tool. Think that works?? Also where can I get this dye you speak of. And besides head gaskets, where else could air get in at
MrMike98
PostPosted: Wed Aug 17, 2011 6:36 pm    Post subject: Reply with quote
try takeing a coolant sample to ur local radiator shop, they can run a quick check for combustion products in that coolant...
just anouther method,
izcain
9sec Club
PostPosted: Sat Aug 20, 2011 8:14 pm    Post subject: Reply with quote
A cylinder leak down test may reveal some clues as well.
9.17 @ 148
jchaussee
PostPosted: Sat Aug 20, 2011 8:17 pm    Post subject: Reply with quote
I don't know how to do leakdown test. I am going to try chemical test first. Would a leaking exuast manifold let gas into cooling system??
PostPosted: Sat Aug 20, 2011 8:18 pm    Post subject: Reply with quote
No.
Compression to coolant leak is head gasket, cracked head, cracked block.
jchaussee
PostPosted: Sat Aug 20, 2011 8:24 pm    Post subject: Reply with quote
With my compression numbers being so close, and the fact I have 882 heads, would it be a decent assumption that heads have small cracks. I am not showing any of the other signs of broken head gasket such as overheating, coolent in oil or smelly exaust
PostPosted: Sat Aug 20, 2011 8:36 pm    Post subject: Reply with quote
How do you know it's building excess pressure?
jchaussee
PostPosted: Sat Aug 20, 2011 8:40 pm    Post subject: Reply with quote
Cause it gets a lot of small bubbles ( foam) it the radiator, also when I start it instead of it flowing nice is just starts spewing out radiator ( if I have cap off)
